Question about Canon Cameras
Sd10 elph green
Sd10 elph turns on, canon logo comes up, green flashing indicator light comes on...everything else is frozen...can not select any mode..the lcd works and reflects settings..but it will not respond to any buttons...it does shutdown on its own when left alone. I've removed both the battery & sd card...tried again.ng .when I remove the sd card and turn on, it indicates there is no card....4+ years old...never had a problem w/ this little gem.
  • jpr2008 Oct 11, 2008
    sd10 elph turns on, canon logo comes up, green flashing indicator light comes on...everything else is frozen...can not select any mode..the lcd works and reflects settings..but it will not respond to any buttons...it does shutdown on its own when left alone. I've removed both the battery & sd card...tried again.ng. When I remove the sd card and turn on, it indicates there is no card.... Taking the battery & SD card out for a while does not help. Previous suggestion was to "reset to factory settings" I can't do anything...4+ years old...never had a problem w/ this little gem.
  • jpr2008 Oct 13, 2008
    Guru:
  • 859 Answers
When you turn on the Camera it goes through a diagnostic self check, this includes the range finder indicated by the green light, next would be the lens operation. Question: when it reaches the point in the process immediately following the Green Light, does the lens start to move and then your camera locks up or does the lens initiate in a manner as you have come to expect these last few years? Typically, your problem indicates an issue with the motor powering the lens controls. This would be consistent with the age of your camera as well. What to do then? Visit a good professional camera store. Every city has one, and they are easy to find by their supplies they offer to the pros who still use darkrooms to develop and print from analog cameras. Their staff should be able to help you diagnose your camera, whether you purchased it there or not. The ability to have and hold your camera and then provide a diagnoses is much more easy than responding to a post here.
Still, reply with the power on cycle of your camera and the function or lack of this from your lens.
Regards,
Worldvet
Posted on Oct 13, 2008
  • Canon Master
  • 1,879 Answers
Kinda responded when turned ON without the SD card. Try another memory card. Post back for any improvements.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Concur with the bad/dead battery scenario. Try to change the battery. Contact with manufacturer if u have warranty. The manual indicates that in order to fully charge the battery you need to charge it one hour after the light on the charger stops blinking.
The first impression of a battery can be misleading if you play a lot with it in order to learn all the controls, furthermore the batteries only seem to have their full capacity after a few charging/uncharging cycles. A fully charged battery gives few hundred shots, without flash.
Thanks
Good luck
Posted on Oct 11, 2008
    Genius:
  • 1,550 Answers
Click the Display button few times until the display turns back to normal it might work sometime if not it must be a more serious issue.
You need to contact the canon because this suggests a loose connector in the internal board of the camera.
  • 1,800 Answers
Hi
if all these soltions does not helps u plz try the following
1/connect ur camera to PC
2/try to upgrade it firmawre usnig the utility that comes with it
3// try it
if u dont ve the utility and firmawre tell me so i can hep further
plz do rate my post
    Genius:
  • 1,913 Answers
Reset it to factory defaults . put away battery and memory card for 15 minutes.
then check.
    Genius:
  • 3,422 Answers
I suggest you to once try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries. you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
  • Priya darshan Oct 11, 2008
    Let me know the result.
My camera is stuck on the blue "canon" screen with a green flashing light, then shuts off, how can I fix this?
Possible causes:
  • weak battery
  • damaged component parts
Solutions:
  • replace battery - if problem continue, refer to manufacture's customer service for help.
  • only authorised service technicians can carry out diagnostics and repaid work.
Sep 19, 2015 | Canon PowerShot 2554B001 SD790 IS 10.0...
Camera hot but won't turn on after E18 fix
Did you make sure that your Canon has fresh batteries and it is in recording mode.?
Dec 31, 2007 | Canon PowerShot SD10 / IXUS I Digital...
Olympux sp600uz flash does not work
You mean, you see the flash logo on the screen, indicating the flash is charged, and then the flash does not fire at all?
Or does the flash logo not appear on the screen?
If the flash does not charge, this could be, because the batteries are low. Or when it takes a very long time before the logo comes on, same reason.
If your camera is on automatic and you did not select flash off, the flash should charge, when you pop it up. The logo on the screen should come on, and when not enough light is available, the flash should fire when you press the button.
Everything in the camera can go defective, but the flash on your camera is made, to last at least as long as the rest of the camera. So make sure you are doing everything correct (like in the manual) before you think the flash is defect.
The manual is still online.
May 05, 2014 | Olympus SP600UZ Digital Camera
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 27, 2009 | Canon BubbleJet i550 InkJet Printer
Flash will not fire on Canon SD780 IS Elph
The flash circuit is defective. As it's only a couple weeks old, recommend just exchanging it for another from your place of purchase. You shouldn't be attempting repair while its under warranty.
Jul 04, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
Canon sd10 elph , screen is black,turn it on or off still black
Try inserting and removing the A/V cable plug a few times (that TV cable that came with the camera that hardly anyone uses). There's a little contact switch inside that turns off the screen when the cable is inserted. Sometimes the switch can become a little dirty with corrosion and can turn off the screen. Inserting and removing the cable plug a few times can sometimes clean the contact switch. Good luck!
Oct 21, 2008 | Canon Cameras
Canon pixma ip90 green light flash then orange light flash 4 times then back to green
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Aug 07, 2008 | Canon PIXMA iP90 InkJet Printer
Cameras Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
