Question about Roper RAS6233KQ Top Load Washer
My washing machine wont spin
My roper washing machine wont spin
  • 8 more comments
  • overweghers Nov 04, 2008
    My washing machine makes loud noise after it fills, when it should start agitating
  • maint man Nov 08, 2008
    will pump out water but will not spin
  • erseymour Nov 10, 2008
    During the washing and spin cycle my machine is making a horrible noise. Not spinning.
  • Patroldog75 Dec 02, 2008
    i have a roper top load washing machine, during the spin cycle it spins slow and makes a noise, does anyone have any solutions for a fix other than a repair shop...
  • Anonymous Dec 07, 2008
    My washing machine will not spin during the spin cycle. What can I do.
  • Anonymous Feb 23, 2009
    top loader won't spin ....makes terrible noise
  • Richard Hutchinson
    Richard Hutchinson Feb 23, 2009
    won't spin makes terrible noise
  • Debra Cunningham May 20, 2009
    Water pumps out it just wont spin
  • john gagnon
    john gagnon May 11, 2010
    HI thanks for your question. will the water pump out. if no replace the lid switch. if yes is it noisey when the motor comes on
  • Anonymous Mar 30, 2014
    washing machine wont spin and ee0 is error appearing
How do you open the top to replace the lid switch?
Posted on Nov 06, 2008
I have a roper washing machine that is not spinning all the water out any clue to the problem
Posted on Nov 03, 2008
3 Suggested Answers
  • 148 Answers
SOURCE: Roper washing machine- unbalanced spin - rocking agitator
I usually stand in front of the washer and take the plams of my hands and forcefully provide a force with the heel of my hands on the side front corners and the lip comes up
Another option is to pull the washer out and remove 2 clips (usually requires quarter inch nut driver to allow the top to come up
This should allow you to get the top off to see if a spring has broken or slipped off
GOOD LUCK!
Posted on Jan 04, 2009
  • 49 Answers
SOURCE: Roper washing machine won't spin
Most likely you are having a problem with your lid switch. If your machine has a hole on the right side, under the lid, you should be able to see a switch just below the surface. An arm on the lid pushes the switch to allow the machine to spin.
For starters I would unplug the machine and put my hand under the cabinet where the switch is. You may feel that it has separated (glue) and can push it back together. If so, there is a chance you can fix it quickly right now. Take out the two screws and pull the switch under the lid (above the tub) to inspect it. If it is separated at the glued joints just push it back together and put a zip tie around it. Put it back in place, add screws, plug the machine in and test.
If parts have fallen out you may need to replace it. I would suggest http://www.partsblowout.com as they are cheaper than anyone else for appliance parts.
If the switch is not separated or you don't have this type of switch let me know and I'll tell you how to troubleshoot other problems.
Good luck.
Posted on Oct 06, 2010
Wash machine wont drain or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 13, 2010 | Roper RAX4233PQ Top Load Washer
Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
May 05, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine wont spin
It broke the drive motor to transmission coupling go to www.repairclinic.com enter model number and look for this part. It's easy to change if you know a mechanically inclined individual.
Dec 23, 2008 | Roper RAS8445KQ Top Load Washer
I have a Roper washing machine Model RA58445KQ that will was but wont spin or drain
If you hear a loud noise when you put it into spin then the motor coupler is broken. Very common problem.
Nov 26, 2008 | Roper RAS8445KQ Top Load Washer
My washing machine wont spin anymore
my washing machine makes a horrible noise while washing and retains water after spinning. what help can i get?
Nov 24, 2008 | Roper RAS6233KQ Top Load Washer
I have a roper washe rmachine it wont spin
washing machine wont wash nor spin when time to rinse
Nov 22, 2008 | Roper RAS8445KQ Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
1,168 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
