Question about Coleman Heating & Cooling
Wiring up thermostat on split heat/cool system
You have stated no problem .only that you are wiring up a stat. thanks for sharing but what specifically are you looking for a stat ? a wiring diagram? what?is it a straight cool ? a heat pump? be specific please .
Posted on Oct 11, 2008
4 Suggested Answers
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
  • 124 Answers
SOURCE: MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Posted on Nov 10, 2008
meBNme
  • 334 Answers
SOURCE: I replaced my Janitrol 7
There should be electric heat strips in the airhandler.
They automatically come on when the unit goes into defrost, the thermostat is turned up more than 7 degrees over the indoor temp or if the outdoor temp is just so cold the HP cannot keep up.
Tat is your auxillary or emergency heat.
What does the new t-stats installers booklet say that the 0170 function and #2 #7 options are for?
If it is for gas vs elec heat then set it on the elec option.
The difference is that in gas heat systems the blower comes on a few min AFTER the furnace fires up to allow the heat exchanger to get hot.
In an electric furnace the blower has to come on emediatly because the heat strips get hot emediatly and if the blower is delayed the system will shut of in high temp overload.
Posted on Dec 18, 2008
The indoor of carrier split type aircon is having a heating function, if they have , how can I set in the remote control
The Split system control is not working and you need to check thermostat wirings and the control on the splitter
Jan 12, 2015 | Carrier Heating & Cooling
Tip
Thermostat wiring terminals and colors
R - The R terminal is the power for the thermostat. This comes from the transformer usually located in the blower section for split systems but you may find the transformer in the condensing unit. For this reason, it is a good idea to kill the power at the condensing unit and the blower section before changing or working on the wiring at the thermostat. If you have a package unit then the transformer is in the package unit.
Red for the R terminal.
RC - The RC terminal is designated for the power for cooling. Some HVAC systems use two transformers. A transformer for cooling and a transformer for heating. In this case the power from the transformer in the blower section would go to the thermostat terminal. It should be noted that a jumper can be installed between RC and RH for a heating and cooling system equipped with a single transformer.
Red for RC terminal.
RH - The RH terminal is designated for the power for heating. See RC above for an explanation. It should be noted that a jumper can be installed between RC and RH for a heating and cooling system equipped with a single transformer.
Y - This is the terminal for cooling or air conditioning and goes to the compressor relay. Typically a thermostat wire pull is made to the air handler on split systems and then this wire is spliced for the separate wire pull which is made to the condenser. Some manufacturers put a terminal board strip near the control board in the air handler so a splice is not needed.
Yellow for Y Terminal.
Y2 - This is the thermostat terminal for cooling second stage if your system is so equipped. Many systems only have a single compressor but if you have two compressors which should only operate off of one thermostat then you need the Y2 thermostat terminal for second stage cooling.
*The most common color I've seen used for this terminal and wire designation is light blue but this varies and is completely up to the installer what color to use. Most installers use the color coding as noted but be aware that some do not use the thermostat color coding.
W - This is the thermostat terminal for heating. This wire should go directly to the heating source whether it be a gas or oil furnace, electric furnace, or boiler,
White for W Terminal.
W2 - This is the thermostat terminal used for second stage heat. There are gas furnaces with low fire and high fire and some depend on control from a two-stage heating thermostat with a W2 terminal. Heat Pumps use staging for auxiliary heat and need a W2 terminal.
*The most common color I've seen used for this terminal and wire designation is brown but this varies and is completely up to the installer what color to use.
G - This is the thermostat terminal used for the fan relay to energize the indoor blower fan. On a split system the blower fan is in the blower section while with a package unit the blower fan is in the outdoor package unit.
Green for G Terminal.
C - This is the thermostat terminal which originates from the transformer and is necessary to complete the 24 volts power circuit in the thermostat but only if the thermostat consumes electricity for power. Many digital thermostats require 24 volts for power so the common wire is necessary.
C stands for common and there is no universal color used for this terminal although black is the most common color I've seen.
O or B - These thermostat terminals are for heat pumps and the B thermostat terminal is used on for Rheem or Ruud and any manufacturer that energizes the reversing valve in heating mode for the heat pump. Most other manufacturers of heat pumps will utilize the reversing valve for cooling and the O thermostat terminal will be utilized for this purpose. This wire goes to outside heat pump condenser where the reversing valve is located.
Orange for O and Dark Blue for B depending on the installer of the heat pump and the manufacturer. If you have a Trane, Carrier, Goodman, Lennox, Ducane, Heil, Fedders, Amana, Janitrol, or any other manufacturer other than Rheem or Ruud you will be utilizing the orange wire for reversing valve. Rheem and Ruud will usually utilize the blue wire for reversing valve.
E - This thermostat terminal is for heat pumps and stands for Emergency Heating. If for whatever reason the heat pump condenser fails and it is necessary to run the heat there is an option on heat pump thermostats for emergency heating. Basically this simply utilizes the back-up heat source many heat pumps have to heat the home without sending a signal to the condenser to run for heat.
E - There is no universal color used for this thermostat terminal designation but this should be wired directly to the heating relay or the E terminal on a terminal strip board in the air handler or package unit if you have a heat pump package unit.
X or Aux - This thermostat terminal is for back-up on a heat pump and allows for auxiliary heating from the back-up heat source usually located in the air handler.
X or Aux - There is no universal color used for this thermostat terminal designation but this should be wired directly to the heating relay or the Aux terminal on a terminal strip board in the air handler or package unit if you have a heat pump package unit.
S1 & S2 or Outdoor 1 and Outdoor 2 - Some thermostats have this terminal and it used for an outdoor temperature sensor. The wire uses for this should be special shielded wire and completely separate form the other thermostat wires.
on Jun 06, 2011 | Heating & Cooling
Tip
Buying the right Thermostat for your Heating/Cooling system
When you feel the need to change you're room thermostat, keep in mind the one that you are changing out, and the type of system you are controlling, such as a Heat Pump split system, or package Heat Pump, a gas fired furnace with a central air conditioning which can also be split or a package unit on the roof or ground, heat or cooling only. For a Heat Pump, you will need a H.P. T-stat as there are up to 8 control wires for these units, to control emergency heat, aux. heat, reversing valve ect. Gas/Electric require only 4 wires, but normally a contractor will pull 5 conductors, one for a spare. On gas/elect. units, the terminals you will see on the new Thermostat will be RH, RC.1st of all, this stands for Red heating, and Red cooling. There will be a jumper wire connecting the 2. The reason for this, is the system you have most always will have only one transformer, to control both heat and cool. If you had a 2 transformer system, you would not need the jumper and you would have 2 hot wires, one for heat and one for cool. They only make these 2 transformer systems for commercial units now, so no worries. Next you will have a white wire.This is for you're heater. There will be a W terminal to connect to. Next, a Green wire, this is for the fan operation, a G terminal. Last you will have a Yellow wire which is for the cooling. Marked Y on the thermostat. In rare cases, they will use the blue wire for cooling. If this is the case, hook the blue to the Y terminal. Now you are ready to program the time and temperature's. Now, if you find you have only 2 wires to work with, red and white, you would more then likely have a heater only. No worries, just terminate the red to RH and white to W. If you happen to have a third wire such as green or blue, this will go to the G terminal for the fan. This goes for a cooling only unit.Red to RC, and white to Y. When using only heat or cooling alone, remove the jumper wire only under this condition. Remember, RH is for heat only, and RC for cool only. You're red 24volt hot wire will terminate there. Now, on a Heat- Pump system, pull off the face plate 1st. The thermostat connects to the sub-base behind it with several small screws. Remove it to expose all wiring and terminals. Due to the fact that most all heat pumps terminate differently, it is VERY IMPORTANT to mark each wire to the correct terminals as 0 to 0, or 0 to B, Y to W-1 ect. Make you make a drawing that you can understand, and mark each wire to what terminal it connects to. Heat-Pumps have several different terminations you must follow, and if possible, buy the stat before you remove the sub-base. Just take the name and any part numbers you may find with you, also you're diagram noting terminals. This way you will no for sure it will be correct. Please don't let this scare or confuse you, I just want to point out that Heat-Pumps have many terminations and you must follow instructions. This should have been noted 1st, but even though us contractors in this field change a thermostat without turning off the power, be sure you turn it off. If not, you may get a light tingle, but you can short out the new stat.Please make a copy of this to keep on hand, and I sincerely hope this has given you some insight on wiring up thermostats.Also, keep the manual that comes with the stat for programming and instructions for different terminations. Best of Luck to all and Sincerely,
Shastalaker7
on Dec 04, 2009 | Heating & Cooling
Need to know how a mobile home split system is wired with just ac and 15 kW heat stripesqqq
you have to have 240 volts for power. 24 volts to operate cool and heat. thermostat feeds color code white to heat yellow to cool green to fan. think of the thermostat as a light switch. transformer in system feeds common to different controls & usually red to thermostat which is then switched to what it is set for.
May 13, 2014 | Goodman CLQ36AR49 Air Conditioner
I am trying to wire a 3107546.008 thermostat but only have 4 wires yellow,red,black,and green
most thermostats for a split system strait cool has four wires,now the heat pumps come with more wires.i'm not for sure what you are talking about.please explain.
Dec 18, 2011 | Dometic Rooftop RV Air Conditioner
Trying to figure out thermostat wiring diagham on a split system
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 05, 2010 | Heating & Cooling
Six wire hook up and new thermostat has only 5
Some thermostats have an extra terminal for an outdoor sensor which tries to anticipate the need for heating or cooling. If this option is not present, you will have an unused terminal which may have a shorting link to a neighboring terminal. Your installation instructions should mention this if the option is or is not included with your model. Also, heat pump systems vary in the system control voltage and not all thermostats and systems are compatible with the more common split system thermostat.
Oct 01, 2009 | Honeywell Electronic Programmable...
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Hot air does not come on
common color code is as follows:
Terminal Wire Color
R RED
W White
G Green
Y Yellow or Blue
This does not guarantee your thermostat was wired to common color code. Assuming it is a single transformer forced air heating and cooling system the following is likely your problem there should be a RC & a RH termial on your new thermostat incase you need a split sub-base for multiple transformers. My guess is that you are connected to RC, if there is not a wire to RH the heat function will not work. the thermostat should have been supplied with a jumper to connect RC & RH together for single transformer applications. If not any small gage piece of wire will work, if I have assumed incorrectly please give me more info about your system.
Dec 11, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
169 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
