Need power cable and control cable for officejet printer t 45
  • 55 Answers
Looks like dead. when powering on, control panel shows "self test" and then nothing shows up on the panel and printer is dead.
Try to reset the memory on your HP Officejet. Do the following:
  • Turn off the power to the HP Officejet and unplug the power cord.
  • Hold down the "# + 9" button.
  • Reconnect the power cord and continue holding the button for another five seconds.
  • Turn the HP Officejet on, and the memory should be reset.
If this won't work, you can try to upgrade the firmware but you can only do this if the printer is still detected by the Computer. You can check control panel and see if the printer is listed as "online" or "ready".
If the above steps won't work. Your printer is deem defective and needs to be replaced. You can try calling HP support for more info. Here's their US number: 1-800-474-6836
Hope this helps.
Jul 07, 2011 | HP Officejet 5510 All-In-One Thermal...
I installed hp officejet pro l7780 but failed to calibrate.
Partial reset the printer
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
May 26, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Officejet 6500 error code 0x61011beb when attempting to install new printer. How to fix?
Your OfficeJet 6500 may need resetting. With the printer power on:
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for at least 1 minute. Plug the unit back in (press the power button if necessary)
4) Wait for the "Insert Cartridges" message. Reinstall the cartridges
5) Close the product doors
6) If you receive a recalibration message, allow the printer to complete this task
7) Reconnect the USB cable
8) Try your print job again
If problems still exist, your product may need servicing by an authorised HP technician.
Dec 20, 2009 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet J4540 All-in-one printer is showing Offline. I have checked all connections and all appears ok. Could you tell me how to change that status to Ready?
It shows offline if the printer is not communicating. Initially open printers folder and right click the printer icon and check if "use offline" option is not ticked.if its ticked then un-tick it. if everything looks fine then:
1)first try unplugging printer from main power cord for a minute and then plug back in and check after refreshing if it becomes ready.
2)other thing to do is to remove the usb cable from behind the printer and plug back in after 45 seconds.
3)it is also quite possible that the usb port or cable might have gone faulty.in that case try replacing usb cable and check.
thanks ,keep updated and accept the solution.
Sep 02, 2009 | Office Equipment & Supplies
I need to see a user manual for hp officejet v 45 all-in-one
GO ONLINE AND ASK FOR IT
HP OFFICEJET 6210 USER MANUAL
OR
HP OFFICEJET 6210 SERVICE MANUAL DRIVERS
OR
HP OFFICEJET FOREM USER GROUP
OR
WWW.HP.COM/OFFICEJET
ROD
Feb 09, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HO officejet J3640 all in one printer
try to unplug the power cable of your printer and DO NOT press the power button just unplug the cable immediately.while the power cable is unplug press the power button for 5 secs.after that insert back the power cable..go to control panel and check if the printer has a green check mark and it syas ready..if the printer doesnt have the check mark or it says offline,right click on the printer and select USE PRINTER ONLINE...try to print again and am sure it will work.....
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
HP 7310xi printer carriage
first removed the carriage assembly lock in place then carefully hold the flex cable at the back
Aug 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP officejet d135 delayed printing
Both the printer and the computer are machines and it solely depends upon the speed of the computer as to in how much time thye data is transmitted to the prinetr to print. Check the speed of the processor, RAM,USB port(if connected with usb cable), length of the usb cable /ethernet cable, distance of the router from the computer and the printer, size of the dcument/image.
Dec 24, 2007 | HP OfficeJet D135 All-In-One InkJet...
56 people viewed this question
jasbo
jasbo
