FixYa.com
Tags:
Fuji FinePix S9500 Zoom Digital Camera
Fuji s9500 Focus Question.
By pandamama - usenet poster
I have asked before about when I take 2 pictures of a pylon (rotating the
camera 180 degrees after the first one), the first picture has the top of
the pylon out of focus and the second picture has the bottom of the pylon
out of focus. I have tried this again using manual focus and setting it
before taking both the photos. The results are the same - the orientation
of the camera depicts which side of the image will be in focus or out of
focus.
Should both photos not end up the same if depth of field were the problem?
Thanks for any replies.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 25, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
may not be a faulty camera, make your aperture higher than it is ..if that dosent work then look down the faulty camera path
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 26, 2006
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
Could you tell me this technique again - and make it a little simpler?
Thanks, matalog.
Solution #3
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
Any other opinions, before I send it back?
Solution #4
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
Looks like your Camera is faulty. Send it in for repair.
Roy G
Solution #5
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
same.
I mean both shots are all in focus.
Solution #6
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
And when I take the same photos with my s602z (with the same settings except
that the s602 lets the shutter speed up to 1/640 at 3.6 aperture instead of
1/500 (which the s9500 gets)) both sides of the image are in focus the same.
Can you Help with these Digital Cameras problems?
battery cover
the battery cover latch was... Answer This...
Fuji Finepix S9500
Hi, When i turn on my camera... Answer This...
FINE PIX s9500 fuji
I have tried to find my manual... Answer This...
need to find lense
I have a Fuji S9500 and would... Answer This...
The command wheel is not... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
