Question about RCA F32648 32" TV
TV shut down, but then tried to power back on,but for some reason could not hold it.kept clicking on and off 3 times and finally quit. Waited awhile then tried again, but had the same result.Finally unplugged the power from outlet and waited for one hour. Tried again but TV failed to power up again. As I said, I can hear the clicking as the TV tries to power up then clicks again and shuts down. I failed to mention that when TV is powered up after sitting awhile, the picture and sound is perfectly normal for about 20 seconds, then shuts down.
2 Suggested Answers
SOURCE:
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
How do I unfreeze a samsung tv screen, NOT a smart tv
Try holding the power button down and with it still pushed in unplugging the unit for a few seconds then release the power and before you plug it back in hold the volume keys and power down at the same time and while holding plug it back in most tvs have a reset sequence hope this helps
Jul 28, 2018 | Samsung Computers & Internet
I was downloading music and my laptop turned off t now says arclibrary update: sorting files... it has been like that for two days what should i do
1. Try ctrl-alt-delete 2. Try "esc" 3. Do a force quit by pressing and holding the power button until it shuts down. Wait awhile and then power up again.
Jan 17, 2011 | Cameras
Green status light FAST blinking and does not shut-off.
SORRY, NO ANSWER.>>> AFTER TURNING MINE OFF FOR THE NIGHT THEN BACK ON IN THE AM, STUCK ON THE WELCOME BLUE SCREEN W/BLINKING GREEN LIGHT BESIDE THE POWER BUTTON. TRIED HOLDING DOWN THE POWER BUTTON FOR 10 SEC., BUT ALL IT DOES IS SHUT OFF. I CAN NOT GET IT TO PERFORM SYSTEM RESET. PLEASE HELP, IF YOU FOUND A FIX FOR YOURS. THANKS! please EMAIL ME AT [email protected]
Nov 17, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
The home screen icons are not showing up on my ps3
the system may be corrupted...i fixed mine by simply just holding down the power button till it shuts off...then i waited a few hours came back reset my powerstrip a few times...fixed the input cords and tv cords and it finally popped up saying somthing like "the system has been corrupted" then just hit ok and then it should restore
Aug 04, 2010 | Sony Playstation 3 (PS3) Console
Awhile ago i dropped my itouch and the standby button on the top of the itouch jammed and it rarely worked. i was playing on it and wanted to go to the menu with the app pages and i kept clicking the home...
Since the sleep/power button is stuck it turned off because holding the top and home button for ten seconds is for turning the iPod off if it freezes so it thought you wanted a hard shut-down and the sleep/power is still being held so it is telling the iPod to turn on but holding the sleep/power button during start-up was made to turn the iPod off if it freezes during start-up. So you may want to take it to your nearest apple store.
Jun 09, 2010 | Apple iPod touch
We have an older Philips tv model 32PS60B121- for a while every time we turned it on it kept turning itself off for awhile, then would finally click on - now we turn it on, the screen is black and there...
yes this is a power supply problem. it has shut down due to a fault, for safety reasons, to prevent a fire or explosion. You need to get a "Quote" for repair. Please note, a unit such as this will more than likely be an un-economic repair.
Mar 19, 2010 | Televison & Video
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
Rca tv hdtv wont come on
The set has a processor that has detected one of about 30 different problems, When this happens it shut the unit down for safety. A technician has special computer interface equipment that can read what errors have caused the set to shut down. I would have to troubleshoot this set further to know what it could be. sounds like it could be a compent that has finally decide to fail.
Jan 17, 2008 | RCA HD52W59 HDTV Projection Television
RCA F32648 32" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
