Question about Whirlpool LSR7333 Top Load Washer
Water Overflow While loading washer and water was filling the washer I was interrupted, stopped the washer for a while and and had to come back. Once I resumed and put the washer on, the water keeps on filling without stopping....floods the basement. This has happened twice, any solution? BTW if I load and fill water in the same shot, close the lid, etc. - no problems.
  • loldup Oct 11, 2008
    Squishy2, Thanks for the info, will look over the lid switch and cable.
    Sergeant:
  • 409 Answers
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Posted on Oct 11, 2008
  • Carmen Mikulic Oct 11, 2008
    hello again,
    please let me know how it turns out and if i can be of more assistance.
    thanks again.
    c
Roper top loading washer RTW440VQ1 will not stop filling up
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 22, 2012 | Roper RAX4232KQ Top Load Washer
Model # 110.26832692 does not stop filling up with water when the load selector size is set will overflow if I don't stop it!
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps to figure out what is wrong with your washer,
Gene
Aug 05, 2011 | Kenmore Washing Machines
Ultimate Care II - water doesn't stop at the fill line, keeps filling to overflow and will not agitate
If the washer overfills, it may be something as simple as a detached or broken air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The pressure switch on top loaders is located behind the load level selector knob on the operator console. The pressure switch on front loaders will be located inside the cabinet, usually mounted along the back interior wall. In the case of certain Maytag front loaders, the pressure switch is actually located under the tub. The principles of operation on all of them is the same, though. They all have an electrical connection and an air hose that detects the pressure from the tub as the water level rises.
If the pressure switch is not able to detect the water level properly, it will not shut off and the washer will never begin the wash cycle. Instead, you get a tub overflowing on your laundry room floor.
Read through the link provided and let me know if you have any questions. I hope this helps you.
NOTE: Another source of an overflow could be the water inlet valve. This is usually a slow fill fill that you find when the washer is sitting idle over night. A quick test to determine the source of the problem is to unplug the washer. If the water stops - pressure switch. If the water continues to fill - water inlet valve.
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Fills with water but doesn't stop
the washer timer control has failed, u will need to replace it.
Jul 23, 2009 | Kenmore 24032\24036 Top Load Washer
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
Maytag performa
does the water overflow from the waser. also try and fill the washer up with water and when you feel it should be filled to capacity shut the water off to the washer. and turn off the power. After you have done that turn the water back on and turn the power back on to the washer if the water stops running it could be your water valve and is easily replaced. if the water continues to run it could be the pressure switch (water level switch) or it could be a hole in the pressure switch hose.
Dec 30, 2008 | Maytag Performa PAV2200
Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Aug 02, 2008 | Maytag Washing Machines
Whirlpool LSR7333 Top Load Washer Logo
278 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
