My neighbour has changed my password on my router
My router was unsecured , now my neighbour has set a password and i am unable to access my own router
  • 4 Answers
Most routers have a hardware reset switch somewhere on the device. You should be able to find this by looking at your user manual, or going online to lookup the location from the manufacturers website.
Once you reset the device to the factory settings you should be able to use the default password to log in and set a more secure password and secure your wireless if you haven't already done so.
Posted on Oct 11, 2008
Want netgear N600 to be unsecured
To unsecure your Netgear wireless router, turn off the encryption setting in the wireless settings.
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption or turn off the encryption..
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 12, 2012 | NetGear N600 Wireless Dual Band Router
How do i change my connection from unsecure to secure?
the least you can do is set WEP key( in router config) to access the wifi router/AP ( access point). this will prompt client/s to enter password/key if they want to access internet via your router.good luck
Aug 14, 2011 | Linksys WRT160N Wireless Router
How do I set the router to secure from being unsecure
Access the web-server interface inside the router, and change the SSID to a value that _only_ you know, and set the router to _NOT_ "broadcast" the new SSID. Enable encryption, and choose a password for the encryption.
Then, any wireless device that wants to connect would need to _know_ the SSID, and then to _know_ the password.
Mar 03, 2010 | Gateway Wireless-B Router (wbr-100)
Nb200 does not connect to wireless router ( dlink / virgin ) but will connect to neighbours unsecured wirless connection
you need to change your wirless settings.
I gues you have a high level security assigned to your router like WPA-PSK with a passphrase or WEP with 128 bit encryption.
Solution is :
Login to your router page and change the wireless security to WEP 64 bit and assign 10 digit number as a password in key 1. change your wireless name and click apply. and then try to connect to your own chnaged network.
Feb 26, 2010 | Computers & Internet
Did a factory restore, set up wireless, can browse internet via a neighbours unsecured network, but cant on mine. can log in to router wirelessly but thats it no internet
Dide you set up the wireless on your router? If you have done this and you have it set for None for security, you will also be "unsecured", BUT you still have a name (SSID) to identify your network. Check that your internet is set for "Private" access, if you are presented the option between Private and Public.
Nov 16, 2009 | NetGear WGR614 Wireless Router
My wireless is set on unsecured how do i change it to secured
Your wireless router should have come with software, which allows you to set a password on it. Install the software on your PC. Then run it. It should discover the router. You log in with
username: admin
password: admin
then you should be able to set the password.
Another way into the admin interface, is to type the IP address in your Internet browser if you know it (often 192.168.1.1)
Jan 09, 2009 | Linksys EtherFast 4-Port Cable/DSL Router
Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Security
Till the time you put a access code for the wireles it would show it as a unsecure connection.You can change this by accessing the router page.Just type 192.168.1.1 in the address bar of internet explorer.Than it would ask you for username and password.Its ussually admin and the password field blank.Than go to wireless settings and the security to WEP.than you can put a password of either 5 or 10 digits.U can put your phone # which would be easy to remember and than just save the setting.Next time when you would try to connet to it than it would ask you to put the access code and will show up as secure connection.
I hope that helps
Dec 25, 2007 | Linksys A+G WRT55AG Wireless Router
Renaming Linksys BEFSX41 router and securing it.
It sound to me that you have a wireless card in your laptop and you are picking up your neighbors wireless router!!!! which has no SSID set, thus "default" and has no encryption set, thus "unsecured network". Turn off your wireless adapter The only security on a Non-Wireless router is turning on the firewall. It should be enabled by default. The other thing would be to change the password on your router, but since you do not have a wireless router, then it is pointless, unless you do not want someone in your house to access the router settings and make changes. Ever then, if someone in your house that is physically connected to the router with a "cable" could alway walk to the router and stick a pin in the the "reset" hole in the back of the router to reset wipe any changes that was made, so a password is pointless as far as I am concerned for non-wirelss routers. open your browser and type http://192.168.1.1 Admin User name: Leave it blank Password: admin Once you login you can change your password if you like.
Aug 23, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
