Question about Car Audio & Video
Where can I get the code to get my radio to play after a battery replacement for a 2001 Dodge Intrepid
  • jwfduke Oct 11, 2008
    This is a factory installed premium system. It has AM Stereo & FM Stereo Radio with Graphic Equalizer, Cassette Tape Player and a 4-Disc CD Player. The speakers are Infinity premium sound system. I simply changed the battery and now it will not turn ON. It is a 2001 Dodge Intrepid Car.
  • 10,594 Answers
What is model and brand of your car radio?
Posted on Oct 10, 2008
  • Shahid Electronics
    Shahid Electronics Oct 11, 2008
    Thanks for info, please contact your car dealer to unlock it as its custom designed system and requires code. You can check code in instruction documents supplied with car.
    If you feel uncomfortable with above solution, please unrate this solution and post back.
    Thank you.
For a 2001 Dodge Intrepid 2.7; PO622 and PO403.
If you go to alldata.com you can get more info on those codes, look for tech service bulletins on the EGR issue.
Jul 24, 2014 | 2001 Dodge Intrepid
2001 Dodge Intrepid- What does P0622= Generator F-term. Field F control, and P0403= EGR flow circuit malfuntion mean? Thank you
If you've replaced those parts according to the codes, you need to have the codes cleared from the computer, otherwise the car will think you still have the bad parts on, and stay in what they call Limp Mode! Sometimes you can take it to an Autozone, and they can clear it for you! Otherwise you need to have a shop clear those computer codes for you!
Apr 18, 2014 | 2001 Dodge Intrepid
How do i disconect the battery in my intrepid
make sure you have the radio code first.(you may not be able to reset the radio if you do not have it). disconnect the earth wire on the battery
May 26, 2013 | 2001 Dodge Intrepid
Code p0201 on in dodge intrepid 2001 steady not blinking
P0201 Injector Circuit Open Cylinder 1
replace your fuel injector
Jan 14, 2013 | 2001 Dodge Intrepid
I got a 2001 dodge intrepid i was driving down the rd n the car went dead lights radio still work we replaced the battery yesterday car wants to start but wont finish turning over
Have a qualified person check the alternator to see if it is charging the new battery. Oh and check the belts on the motor. And the pulleys. If the belt is missing, it needs to be replaced. If a pulley is bad, get a new one.
Aug 10, 2012 | 2001 Dodge Intrepid
How do you remove the radio
Here you can find two reference guides:
- Dodge Intrepid 1998-2004 DG-50-98
- Dodge Intrepid 1993-1997
Hope helped with this (remember rated this help) Good luck.
Oct 23, 2009 | 2001 Dodge Intrepid
Car doesnt start
Did you check to see if your old starter was any good, you may have a bad spot on your fly wheel and it is getting caught up on the bad spot and it want start try turning your fly wheel of the bad spot and then try to start it.
May 03, 2009 | 1999 Dodge Intrepid
Battery replaced on 2001 grand dodge caravan now radio dont work
U will need to enter the radio anti theft code, this lock out was triggered by the loss of voltage to the radio during the battery change, this code is unique to each radio and cam in the owners information packet when the cat was sold new.
Apr 13, 2009 | 1997 Dodge Stratus
After dead battery, radio won't work. lights...
you need to call your local dealership and they will give you the code to reset you radio.. good luck keith..p.s. remeber to write down the codes, that way if it happens again you will have the code for the radio..
Mar 21, 2009 | 2001 Dodge Intrepid
After dead battery, radio won't work. lights flashing
First I would try to disconnect the negative cable and then reconnect the cable. See if it resets.
Mar 21, 2009 | 2004 Dodge Intrepid
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
