Question about Tomtom ONE GPS Receiver
GPS can't find signal
Put in all pertinent info place starting and destination required, no signal came up, kept looking for signal for several hours didn't get signal. We were in the city of Calgary Alberta at the time.
    President:
  • 2,712 Answers
Do you have the updated version of the map?
Posted on Oct 11, 2008
  • Swilin Sampson
    Swilin Sampson Oct 11, 2008
    Please see this article from TomTom website for complete troubleshooting steps for your issue:
    http://www.tomtom.com/support/index.php?...
    Hope that helps! Please don’t forget to "Accept"
    the solution if it helped you in any way, or leads you to a fix.
    Thank you for using FixYa!
    Cheers!
    IrishDruid
How to downlpoad navigation path
really need your question to have more info.about what your trying to do. if you put in your home address and then go to navigate and type in your destination as it ask you to do, then the gps will automatically navigate you to that destination.
Jan 03, 2015 | GPS
No GPS signal
Ok Marilyn,
Thanks for the info. Your device has no dedicated reset button like some other Tom-Tom units, but it still can be reset.
To perform a reset, make sure that the unit has a fully charged battery. Charge for several hours if unsure - and make sure the charging light comes on (if it doesn't - it will probably need service) while connected.
Disconnect from charger.
Press the On/Off button to turn the unit on (if not already on) and allow it to start up as usual.
Press AND hold the On/Off button for up to 15 seconds or until the unit turns off.
The GPS should now be reset, and should work as expected when you next turn it on. Good luck!
Apr 15, 2012 | GPS
Whenever i put in the address from which i am leaving to go to a destination it wont do anything and also in the car it wont show me the road that i am on
When the GPS device starts up ( when you power it on ), it will take several seconds, up to a couple of minutes to locate the satellites, before it will show where you are (on the road / map). So, you simply have to enter the destination address, to get directions from where you are, to the destination.
It is easier for the GPS device to locate the satellites if the GPS / you are not under (some) cover, e.g. indoor garage, under ground parking, under trees, etc. Some times you'll just have to wait a little longer. [But you can enter the destination addresses even before it locates your position ]
Feb 13, 2011 | MyGuide MG 3100 Car GPS Receiver
I can not delete my previous destinations, I can not reload my info from memory card, I can not save my destinations, and I can not find the reset button. Thank You.
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 21, 2011 | Magellan Maestro 4700 Car GPS Receiver
Was just given a TomTom and car adappter to use on my trip from MI to MD. I've never used a GPS and no manual was included how to program it from start to final destination
The TomTom only needs for you to enter your destination address. Once that's in, you're ready to go. Along your route you can tap the center of the screen to find POINTS OF INTEREST such as FOOD, LODGING, etc...but will retain destination info 'til either cleared or changed to new destination.
To enter your destination, tap center of screen. There you choose house address, business address or city's center. If you choose street address screen opens to:keyboard. Type in destination State, ie; Maryland. Once you've typed state, hit DONE in bottom right corner. The screen then goes to CITY. Type in destination city then hit done again. Follow the same steps for STREET NAME & HOUSE #. Click DONE & CONTINUE as prompted. TomTom will then target your location and you're ready to hit the road. It will show you your distance and time (ETA). It will also show you the speed limit where you are and the actual speed you are going.
When you pull over for gas, food, lodging, shopping, sight-seeing or whatever, it will automatically account for this and will continuously update your coordinates to get you back to the highway/road you need to be on. And when you're ready to come back to MI all you have to do is hit the home icon and it will automatically map your trip back.(Home is - or should be - set to the home address of the owner of the GPS).
All-in-All it is user friendly and very simple to use.
If you need additional info, please don't hesitate to ask.
I hope this info was helpful to you. Good Luck!
Have a great trip and drive safely. :-)
Jan 31, 2010 | Tomtom XL 340S Car GPS Receiver
Garmin nuvi 705 won't power up
probably a bad piece in the hardware (power supply). these come with a 1 year warrenty. I would contact garmin and have them take a look (they will replace it most likely)
Jun 26, 2009 | GPS
In the car my tomtom is saying waiting for a valid GPS signal
press the reset button on the side and wait for about 3minutes...
Mar 29, 2009 | Tomtom ONE 3rd Edition GPS
Want to customer program a destination
What if you map out your destination across southern Nevada by city then north to Minnesota. Create one, two or several city destinations in the GPS favorites. As you get to each city you will hafta put in the next city. Unlike mapquest you can't add another city (destination)and unlike yahoomaps.com you cant slide the route to change it. does this help? tinkr
Jan 10, 2009 | Nextar Q4-04 Car GPS Receiver
"Searching for Satelite" - unable to find
10-15 minutes is normal.
Did you take it outside? GPS doesn't work indoors. Try in an open field, no trees. Should lock in a few minutes. I always do the following: i key in the destination address at home, then put it under 'favourites". When i start driving, i put the unit in my car and look up the recently added favourite. The unit then has enough time to lock on to the satellites.
Jan 07, 2008 | Navman F20 GPS Receiver
Tomtom ONE GPS Receiver Logo
64 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
