Question about Toshiba Satellite A105 Notebook
Startup issue out of the blue i started my toshiba,it goes thru the xp and toshiba screens,then has a incorrect shutdown screen,which gives me 3 safe mode options,one start in most recent config that worked and one that starts windows normally.none work...all end me back in the same place...a 30 second timer.
  • 1 more comment
  • wbcoyote64 Oct 11, 2008
    intel
  • wbcoyote64 Oct 16, 2008
    will try either solution,but first have to get an XP disk,which i should have tomorrow.
    thanks for the suggestions,i will let you know what happens!
  • John Hong
    John Hong May 11, 2010
    What processor does this have? Intel or AMD?
  • 4 Answers
OK, here's my suggestion but 1st a question, did you by any chance just finish running a anti-virus or malware scan before this happened?
I have seen a lot of computers where the winlogon file called userinit.exe gets infected by a virus and then is wiped out by a malware scan. So the registry entry points either to nothing or an incorrect file
To replace userinit.exe:
1. Boot using Recovery console (or other cmd prompt with access to C: drive)
2. CD Windows\System32
3. Expand d:\i386\userinit.ex_ userinit.exe (or Copy d:\i386\userinit.ex_ userinit.exe) where d: is CDROM drive and need to expand compressed file to full file.
4. type Exit to reboot
Try that!
OzMont
Posted on Oct 15, 2008
  • Toshiba Master
  • 787 Answers
Ok, that rules out the problem some systems with an AMD processor have with SP3.
Before we try anything else, unplug the computer, remove the battery and leave it like this for a few minutes. But the battery back, plug it in and try it.
If that does not work you will need you windows CD.
Put it in the drive & boot to the CD
You need to press R and go to the recovery console
type chkdsk /r
If this does not work, repeat and this time type fixboot
Posted on Oct 14, 2008
Some problems in laptop
Have the hard drive tested for issues, from your description it is the harware that is causing the problems.
Jun 27, 2012 | Computers & Internet
Cannot start windows or launch startup repair. Loads windows icon then flashes blue screen then black screen with large cursor
It might be just a software related issue, i suggest you boot into safe mode(tap F8 repeatedly during POST), if you are able to access safe mode without any issue, you can perform a system restore. This will allow the computer go back in time when the issue is not yet present. Hope this helps.
Apr 14, 2011 | Toshiba Satellite L455DS5976 Notebook
Laptop wont start windows xp pro. goes to a blue
Take one memory stick out and test. Then do the other. Also checking each memory slot.
If not solved. When the computer starts, continually press F8 until you get startup menu- select SAFE MODE and fix the driver or software that is in startup
or
Roll back to last known configuration that worked.
While you are there- disable Auto Reboot on Failure.
May 02, 2010 | Computers & Internet
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
I have an acer aspire 5315 and on start up it goes to a screen about windows not starting up correctly gives option to start in safe mode, last known good configuration, and start normally. If I choose to...
This can be caused by a hardware failure (e.g. hard drive, etc.) or an operating system (OS) issue. Either way I would recommend taking it to a computer repair shop so they can diagnose the issue.
If its an OS issue most likely the cheapest way to fix it will be reloading the OS on a new hard drive(because its cheaper to buy a hard drive then have a company backup your data) then plug in your old hard drive to get access to your data.
Nov 12, 2009 | Acer Aspire 5315 Notebook
Won't boot - brief blue screen
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
May 30, 2009 | Computers & Internet
Blue screen on Thinkpad R51e & cannot be shutdown
what operating system are you using and please be more descriptive regarding "blue screen" is it the notorious microsoft "Blue Screen of Death"? or? when this occurs is the system totally locked? or can you hit ctrl alt del and get the task manager? can you boot into safe mode? if you're using xp and can get to safe mode.. have you attempted to restore to an earlier restore point prior to this issue? if yes and you haven't restore back to before issue occured.
May 20, 2009 | IBM ThinkPad R51 Notebook
Toshiba laptop, xp, wont start up.
Perhaps the shutdown corrupted a critical Windows startup file. Have you tried a Windows repair? You'll need the Windows XP CD to do it. An explanation is here: http://www.michaelstevenstech.com/XPrepairinstall.htm#RI
Jan 31, 2009 | Computers & Internet
Toshiba satellite laptop comes on and stays at windows xp page
If Safe Mode doesnt work then you may have to do a "repair" of your O/S. Place your Windows XP CD into the CD-Rom drive, reboot and once you see the options if you want to Install or Repair - choose Repair. This option will make repair to your O/S and for safe mode.
Once repair is complete do a complete Anti-Virus and Spyware scan of your Hard Drive. If you can boot into Safe Mode to run the ani-virus much better.
Dec 28, 2008 | Toshiba Satellite L35-S2366 Notebook
Toshiba Satellite A105 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
