Question about Polaroid FDM0700A Under the Counter 7 LCD TV with DVD Player Television
Polariod FDM0700A there is no sound coming from the tv
The unit comes on using the power button as well as a remote and displays "Polariod" on scrfeen and then nothing else, no sound no picture?/
More than likely your power supply needs two electrolytic capacitors, 10MFD @ 450 WVDC. If you find the capacitors on the power module to the top of the metal enclosure inside the tv, they will probably appear to have swollen tops.
Mar 01, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Polariod flat screen tv when powered up power
your right there will be a bad caop in the power supply the can will have a domed or puffed top the value is printed on the side replace it and it will all set to go
Dec 23, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Black square covers pic had tv 1yr see part tv and hear sound
Turn off the Sub titles from the menu using the remote
Feb 27, 2009 | Televison & Video
I have no sound on my 32 inch polariod tv none at all please help
What it sounds like is wiring inside to the speakers got disconnected. Does the TV have a jack for headphones or external speakers? If so, then I would connect something to see if you get sound.
If you still do not have any sound, then your audio outputs may have fried.
Jan 17, 2009 | Polaroid FLM-3225 32 in. LCD Television
My Polariod has no douns but great picture??
Make sure the speakers aren't turned off. It will be in the menu section under audio or sound. If you can find no other reason and you take the back off the set, look at the top of the bottom board. With a ohm Meter look for a Suface Mounted Resistor at the top of the board marked 100. Check the resistor on ohm . If it's over 100 ohms replace it. I don't think your dogs to blame.
Oct 10, 2008 | Televison & Video
Polariod tv flu 324 25a
i have a polaroid tv dvd cmbo and the dvd will not load a moving indicates it is loading sounds like it's loading,but nothing happens can yu help?
Aug 15, 2008 | Polaroid FLM-323B Television
Polaroid FDM0700A Under the Counter 7 LCD TV with DVD Player Television Logo
23 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
