I have a Brother MFC-8440. I dropped the paper tray and two small springs fell out. Now the paper stack will not pop up when the tray is pushed in and the feeder can't reach the paper..... I know these little springs go somewhere - I believe it has to do with the little plastic finger on the bottom of the tray. Is there an assembly picture somewhere on the web that can show me where these darn springs go? Thanks.....
  • Anonymous Apr 01, 2009
    I had the same exact problem with the paper tray and thank God for Joed911! I saved immeasurable time and money thanks to this diagram! Thank you Joed911!
  • 4,338 Answers
Here is the parts breakdown PDF: Fig.8 is the paper tray .
http://piese-imprimanta.ro/pdfs/1148_DCP_8040_8045D_8045DN.pdf
You may have to copy and paste link into your browser.
Also, I can fax you the page if needed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 11, 2008
  • JDTec
    JDTec Oct 11, 2008
    I an email it to you too
    Joe
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
Brother Laserjet 8860dn printer not picking up/feeding paper
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Oct 01, 2009 | Brother MFC-8860DN All-In-One Laser...
Brother mfc 8440 paper tray is open about 1-1/2'' and is stuck and won't come out or go back in. There is something locking it in place. The spring-loaded paper bed is in the up position and won't move....
1. I took bottom metal support bracket off, probably didn't solve issue.
2. Adjusted paper width guide, on gears, when I did that, spring loaded piece that paper lays on released, pushing down, and I was able to remove paper drawer.
Sep 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
BROTHER MFC 8440 ERROR "NO PAPER"
Check the paper tray adjustable guides inside the tray; the guides need to fit around the paper snug, when re-inserting the tray if the rear guide is back too far the paper may be shifted towards the front of the tray out of range of the paper sensor so it thinks it's out of paper. I service HP LaserJet printers and most of the time this is the problem. Hope this helps.
Mar 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Paper jam How do I correct this? There is no paper along any pathway!!
does it ever reset by opening and closing front door? if not, there could be paper stuck in fusing area behind rear door. open and inspect. if you see no paper, pull drum unit out and locate open slot in the bottom, center of drum unit. could be a small scrap of paper in that slot.
hth,
razors
Jan 28, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 shows "manual feed" and will not feed from tray
go to your cpu in the printer set up and tell the printer what you want it to do
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Hello, I have Brother printer MFC 8440.I keep getting mesaage that i have paper jam. I checked all places and there is no paper jam.How can I fix that problem?
It's possible there is still a very small scrap of paper left. If you have a can of air blow it in and try to dislodge it. If that doesn't work try to unplug it wait a minute and plug back it.
Dec 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
129 people viewed this question
k24674
jasbo
jasbo
