Question about Zenith C27A24T 27" TV
DTV converter Box and Zenith system 3
I just bought DTV converter Box for my 27" Zenith system 3, perhaps made in 1980s. No Signal, I've even manually entered the Channels but still no signal. Converter Box is Magnavox TB100MG9.
So I purchased two brand new Anternas, still no signal. When I test the signal with the Converter Box it show no signal, none. But when I connect just the Anternna direct to the TV, at least I am able to watch the TV though it snowy.
My question is... is this TV so very old for DTV Converter Box?
  • secretscry Dec 09, 2008
    I have the Same problem, but I live far away, I pick up normal signal, but the box picks up nothing (not even if the antaina is picking it up) what is the deal?
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Posted on Apr 14, 2009
    Problem Solver:
  • 14 Answers
Make sure the TV is set to channel 3 if that is what the output channel is set to on your converter box. You can also test the TV by hooking up a good VCR to the TV and play back a good tape on the channel that VCR is set to output on. Now the important thing to remember if the setup is correct is that with Digital signals, you either have it or you don't. If the digital signal is too weak, it will show up as "no signal" and you may have to invest in a good outdoor antenna, rotor and good antenna amplifer to get a viewable picture, especially if the station you are trying to receive is over 50 miles away. Hope this helps, your TV is probably not at fault.
Bill
Posted on Oct 23, 2008
TV no longer will find channel 3. The lowest channel number is now Cannel 4. My DTV box works on channel 3 and it no longer works with the TV
If you re using 'autoscan' on your TV to find channel three and it doesn't find it, the converter may not be supplying any signal for it to find.
Try using manual setting of channel three and you will see if there is any signal available. If you don't know how to manually select a channel, try the box with another set.
Mar 07, 2011 | Zenith TVA1321 Combo
HD Converter Box through VCR to TV
you need a dtv converter box like this one.
Aug 07, 2008 | Televison & Video
Is my rca f27442 tv digital compatible?
Sorry no.All CRT(tube tvs) are analog tv.It all digital now,must have Digitial converter box and a roof or digital antena to get the analog tv to get the free DTV digital signal.Or u must cable tv.Only LCD tvs have the digital tuner insidide to pick up the free DTV digital signal without the converter box.
Sep 02, 2010 | RCA F27442 27" TV
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Not DTV ready?
it meens the tv set is in dtv and the dtv conection is not set up.
hd tv is a red blue a green cable.
and the antena conection needs to come from a converter box if signal is coming from antena if from sat or cable you should have a hd box that feeds your set.
hope this helps.
daniel.
Jan 13, 2009 | Panasonic CT-27SC13 27" TV
I'm looking for rabbit ears/antenna for my Durabrand T.V.
Radio Shack, Wal-Mart, etc. all carry a selection of antennas that will work with your converter box. Depending on the strength of DTV signals in your area, you may need an amplified antenna (has a built-in booster) to get good reception. Analog broadcasts were watchable with a weak signal (the picture would just be fuzzy), but the digital system needs a good strong signal. The sales people may be able to suggest an antenna based on what other customers have purchased and their reports of how well they do. Outdoor antennas are also available if needed.
Jan 12, 2009 | Durabrand BH1304D 13" TV
Is the tv that I have bought about 6 years ago ready for DTV?
6 year old tv probably not digital ready. The converter box will work if tv is on channel 3 and you use a UHF antenna. Most converter box connections have 75 ohm connectors, your tv may have the round connector to accept the input signal. If you have screw on terminals on the tv you will have to go to Home Depot or Lowes and get a matching transformer to go between the tv and the converter box. UHF antenna can be made out of a coat hanger. Just make a circle clean the paint off ends and attach. Or just buy a digital booster antenna at WalMart.
Jan 11, 2009 | Daewoo DTQ-27U4SC 27" TV
Magnavox 20MF500T/17 will not interact w/NHENS DTV Converter box
The tv just needs to be set to channel 3 or 4 to pick the signal up from the converter box.
Jan 10, 2009 | Philips Magnavox 27MS343S 27" TV
Zenith dtv converter, favorite channel button
Found the solution in the user manual. You have to go to the 'edit channel' section of the on screen menu.
Dec 30, 2008 | Zenith C27A24T 27" TV
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Zenith C27A24T 27" TV Logo
517 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
