Question about Brother FAX-575 Plain Paper Thermal
Cartidge jams when trying to print a fax
The paper feeds in ok but comes out smeared and illegable.
Opening the case shows the printing film bunched up. It's not being wound on to the takeup reel.
  • dixid
    dixid Oct 13, 2008
    I have the same problem. The only ribbon that did not bunch up was the demo ribbon which came in the original box. I think it might somehow be related to using "compatible" ribbons. Does anyone have an answer?
    Scholar:
  • 75 Answers
I use to sell the generic ribbons. they have a lower heat transfer. the ribbon starts melting to the paper & causing all kineds of problums. Sorry to say you need to buy name brand.
Posted on Jan 30, 2009
What's your problem?jam single check cant remove from auto feed tray. I opend side door I dont see the check. where is it? scx-6345-N
It is difficult to get the check for reuse. It can be located. If the printer is not flashing signal of paper jam then take a test print on A4 size from the printer with full page matter. If you are getting this print with smears in particular area of the paper then you can be sure that the check is wrapped around the fuser roller/film inside the fuser assembly. The fuser assembly is located at the rear side of the printer which will be visible only after opening the back door/cover.
Sep 21, 2011 | Office Equipment & Supplies
Epson C86: paper not feeding and prints at an angle
try feeding the paper through manually if you cant do this then try printing a blank page and see if this still wrecks the paper if it does then it does sound like something is jammed on the roller the best way to clean this is with a blast of air from a compressor this is the only sollution as it will cost more to replace the parts than it would to buy another printer if it is still under warranty they should replace it for you if not you could take it to a computer repair shop where they will strip it down adn rebuild it for you this is a paper feed problem but im sure their must be somethig sticking in the way or maybe the paper feed has come lose at the one end sorry i couldnt help you any more ........................................
Oct 31, 2007 | Epson Stylus C86 InkJet Printer
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
1: the paper jams when it tries to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 11, 2009 | HP DeskJet 712c InkJet Printer
HP OfficeJet 7310
showing paper jam and have checked and don't see any paper
Dec 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
Brother FAX-575 Plain Paper Thermal Logo
109 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
