Question about Frigidaire GLER642A Electric Dryer
GLER642A dryer heating element
Please help me. I can not figure out how to get the heating element out. I have the dryer open. Top and front off, about 20 screws and cut up hands! Ugh!
    Sergeant:
  • 291 Answers
Things that could stop a electric dryer from heating: - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug
Posted on Nov 23, 2008
  • jamesrated Nov 23, 2008
    Meter testing and usage tips.
    1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
    2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
    3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
    4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
    5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
    6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
    7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
No heat for the dryer, drum turns, breakers good
Check the thermal fuses / temp sensors mounted on the top exetrior of the heating chamber and also the heating element. Both accessible from the rear of the machine.
Nov 08, 2009 | Frigidaire GLER642A Electric Dryer
The heat doesn't work. Please assist.
Check your thermostats and your heating element, this normally causes this problem
Sep 20, 2009 | Frigidaire GLER642A Electric Dryer
Suddenly the dryer stop heating
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Frigidaire GLER642A Electric Dryer
No heat
You gotta pop the top and remove the front which is very easy. Access the idler and remove the belt and get the tub out.. Here is a quick guide
Apr 04, 2009 | Frigidaire GLER642A Electric Dryer
Heating element turns on when you turn on timer door open
Sounds like the door switch is broken.Fairly easy to replace.
Feb 16, 2009 | Frigidaire GLER642A Electric Dryer
Heating element
1. pop the top
2. remove the front
3. remove rear access panel, get belt off motor
4. remove drum retainer(where applicable)
5. grab belt at top of drum, using belt as handle, yank it straight up off the rear bearing mount( do not remove the screws inside the drum)
Jan 31, 2009 | Frigidaire GLER642A Electric Dryer
Changing heating element on a frigidaire dyer
If you dryer lint screen is located at the top of your dryer your heating element is going to located at the rear of your dryer. You will need to remove the back of the dryer to get to it. You will see a housing and the element is located in there. If you lint screen is located in the door when you open the door then your heating element is located in the front. This one is easier to get to. Simply remove the bottom panel under the door and you will see the heating element right at the front on the right hand side. Make sure you unplug the dryer before working on it. If you have any other questions feel free to ask and also please let me know if this was helpful for you. Good luck and glad to help.
Jan 22, 2009 | Kenmore 63942 Dryer
Heating Element for Whirlpool Dryer: GEW9200LW0
I think on this one you can take off the bottom panel on the front and get access to the heating element.
Dec 16, 2008 | Whirlpool GEW9200L Electric Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
127 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
