My Mitsubishi WS-65517 65 inch
Sorry i am not sure how to answer your soulution? I used the add a comment but i don't know if that will get to you. But anyhow, yes it happens when i change the channel with the remote or at the front panel.
  • 10,594 Answers
I got your comments in 1st post and replied.
Thank you.
Posted on Oct 10, 2008
Mitsubishi WS-65809 Iris problem
i KNOW THIS SET WELL and it has no such option.
I am not sure if you really want an answer as you post this repeatedly and do not respond to comments.
picture is very dark and blurry?
Mar 30, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi 65 inch rear projector TV with remote. Model WS65807. HD ready, but not HD. Has failed circuit board, part number 930B866001. This board regulates audio and video. Part no longer available...
Short answer: No.
The board and install will cost you more than an LCD/LED flat screen TV.
Sorry for the bad news, but you will save space and electricity with the new TV.
Next problem: Trashing the projection TV.
Oct 25, 2017 | Mitsubishi WS-65807 65" Rear Projection...
SCREEN HAS VARIES RED -BLUE-WHITE- LINE SHOWING, I TRIED USE THE
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
46 Inch Mitsubishi PRoj. TV. 7 years old. Starting to randomly lose Cable signal, than come back up after a few seconds. No predictable time of the day or duration. Any pointers will be appreciated.
Most likely the set is loosing the ability to tune channels. The tuner will need to be replaced. If you have a cable box set up or even a VCR you can use that for your tuning and use the television as a monitor and use the video inputs on the back of the set. They are the Yellow, White and Red connections. You may also be able to use Ant-B, as it has a separate tuner.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
May 14, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi ws-65807
I suggest to visit the website of manufacture to have both question answered . thanks
Apr 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55311 answer you gave me.
Before you replace a board, please double check or use different cables, make sure the cables are in the proper out/inputs, rgb to rgb. Try 'comp' 2. Composite vs component uses two different paths to produce a picture. Also, after taking tv's back off ensure that all boards are seated properly, since this happened after movement. CAUTION: make sure the unit is poweless, unplug tv. Let me know. Good luck....
Apr 03, 2008 | Mitsubishi WS-55311 55" Rear Projection...
NO Sound
Sorry, you need to try and add some more detail to the problem. It could be anything from a bad connection however your TV is setup or the speakers died.
Things you could answer to help, does sound work on any source, or does it only not work on one in particular? What were the circumstances around it? What changed around the same time? Have you tried resetting the tv to factory settings?
Dec 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
