Question about Toshiba Satellite A135-S4527 Notebook
USB ports not working
My Toshiba Satellite A135-S4527 is not communicating with some of my USB devices. It recognizes the printer, but when I try to print something, it gives me an error that says "cannot communicate with printer". My mouse doesn't seem to read at all. I have tried both devices in all four ports and had the same problem.
  • Ziuzchu Oct 16, 2008
    I have a similar problem, only none of my USB ports are working. I've updated the drivers. I think it has something to do with some graphic software I updated because it happened around the same time. I also read that it's one thing that can cause this. Only problem is I can't disable or roll back the driver. I really need my mouse! Please, anybody out there know what I can do??
    Thanks
    Genius:
  • Toshiba Master
  • 1,250 Answers
Check the status of usb port on device manager, install the updated usb driver
Posted on Oct 14, 2008
How to install bluetooth in toshiba satellite A135-S4527
Doenload and install the Bluetooth driver,
You can download the Bluetooth and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Mar 29, 2012 | Toshiba Satellite A135-S4527 Notebook
How do I connect a printer to my laptop
newer laptop only comes with USB ports. If you have an older printer that uses a parallel cable then it's time to get a new printer or get a parallel to USB printer cable.
Jun 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite memory stick problem
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba satellite a135 s2276. The usb ports are all enabled but it won't recognize any device plugged in Also when i boot up the screen is kinda pinkish in color then goes black. Everything works...
The problem is with your harware. Either there is some problem with your USB ports( Mother Board) or its due to conflicting drives. Reinstall all your USB port drivers.
Mar 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a135-2326 usb not recognized
its a driver issue most likly down to vista (as always) have you tried the latest updates from the microsoft website yet?
Aug 11, 2008 | Toshiba Satellite A135-S2386 Notebook
USB PORTS DO NOT WORK
Turn off computer and try connecting an older mouse to the mouse port. If it works:
Right click Computer>click properties>click hardware>click Device Manager> click USB adapters. Then check to see if some of them are marked. Also you can click on each one to see if each is OK. Make sure that USB is enabled in the BIOS.
Jun 01, 2008 | Toshiba Satellite A135-S2276 Notebook
USB not working after resetting bios on toshiba a135
try using other usb port,,, .. run device manager and remove auknown device file... restart the computer...and also go to the cmos bios and find usb configuration the enable it..
Mar 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
155 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
