My Mitsubishi WS-65517 65 inch Rear Projection Television won't change devices or change the tv channel. Every time i push the button it goes to reset mode. Every time I try one of the two things TV locks up then it goes black and the green light on the front panel flashes green for about 60 seconds then goes out. I have tried a manual reset but still the same. I even unplugged from its power source then plugged back in but no luck. TV turns on fine and i can watch my satilite but that is all. Thanks.
  • rshrews Oct 10, 2008
    Yes. It happens when i try to change the channel with the remote or from the front panel.
    Sergeant:
  • 399 Answers
Try the hard reset and whack test just to make sure it is not something simple.
But, I suspect the controller IC that handles these functions is out of order! OR, could be something as simple as the voltage regulator that supplies the operating voltage for the IR remote control module is defective.
But, it you may need a tech to get inside and take some measurements to catch the culprit in hand.
Mitsu makes a fine set and this one is worth a few dollars to get it fixed up.
Posted on Oct 10, 2008
  • 10,594 Answers
Let me know does it happen when you change channel with remote?
  • Shahid Electronics
    Shahid Electronics Oct 10, 2008
    System control IC seems defective in that case.
    If you know about tv repair, please get service manual of your tv and order part / board. and if you dont want to do repair yourself, kindly call tv tech person.
    Shahid Electronics Oct 12, 2008
    any update in tv
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a 55 inch floor modelmy granddaughter push a button on the front and we dont know which one and there is now no picture but i have sound and can change the channel//we can hear the tv just no...
Look for a button on the TV that says 'source'. Push it and wait for a few seconds, if the picture does not come back, push it again and wait a few more seconds. Do this until you have cycled through all of the input sources for your TV.
Mar 01, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Device selection button locks up TV and after a few minutes turns TV off. Device selection does not function
with the remote press menu2 4 7 0 enter this should reinitialize set when it has reinitialized push reset button on front panel this should cure it. You will have to reprogram your channels and net command though.
Jul 30, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Tv blinks out when front buttons are pushed. model#ws-65511
If the TV is turning on and working regularly, but power button does not shut down and buttons on TV do not work, then it is a faulty touch control (button) board on TV.
If instead the TV does not even turn on, then tv is on protection mode, in that case it can be any internal fault.
If instead the problem is with remote buttons, then it is either a faulty remote or a faulty IR sensor.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
T. V. stuck on one channel showing the device option.
I had same problem and discovered one of the little buttons on the front of the TV was stuck down. Don't know why, unless the maid bumped it hard as we never use them. Anyway, I poked/wiggled a few times at each button and the problem stopped.
Mar 17, 2009 | Mitsubishi WS-65511 65" Rear Projection...
WS-55807 doesn't power on
1) Check all fuse devices in power supply
2)Pc board with transformer possibly defective.............T.
Nov 07, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
