Question about Canon PowerShot A630 Digital Camera
Camera will not start
When I press the on/off button the camera says " lens error- restart camera", but then the camera turns off. Any solutions?
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Oct 11, 2008
My Canon camera turns it self off when I press the start button. the lens comes out & then the camera shuts down. When I restart it the lens retracts 3/4 & then comes right out & shuts down again. the lens...
hi, the camera must also be giving a lens error and must be making a whirring sound when turned on, hold the camera with camera off bang it with flat of hand , a few times , if this does not work , repeat it with camera on, even if this does not, when turning the camera on gently apply pressure on the front of the lens, do this just once , all the above fails , camera has to be service , lens unit may have to be changed
Aug 27, 2016 | Canon Cameras
My Canon Powershot SD 980 IS has suddenly given me a lens error camera restart message. I have changed batteries, called Canon, used compressed air, try restarting with a/v cable etc. Whassup with that. It...
Hello and Welcome to FixYa!
Sir/Ma'am Lens error is because of several reasons and there are several solutions to fix up the Lens ErrorYou have tried One of the most common solution which Fix up the lens error like lens error is solved by removing the batteries and replacing it with a new set of fully charge ones, or Lens error may also solved by compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or Lens error also mostly solves by Insert the cameras Audio/Video (AV) cable, and turn the camera on.
You have tried all these but but problem is still there so problem is quite complicated, well i am suggesting you some more solution which may fix up the Lens Error:-
First of all if your camera allows you to work for minute then try finding and selecting the "factory reset" option to set your camera back to its original factory condition. On some Canon cameras, this requires holding the menu button down with the camera powered on for up to 10 seconds. However note that a lens error might sometimes override the reset option, and thus the option might not appear. So if you find the option then by resetting your camera to Factory Setting may fix the problem
If problem is still there then Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time, This may also solve the problem
Mostly Lens Error is also happens when Lens Barrel is out of position so Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots and it may fix the problem
If problem is still there then there are some other solution too which remove the lens error but all of then are technical and if you try to follow them you enter into the realm of potentially damaging your camera. There is definitely some risk in them, So i recommend that if your camera is still under warranty, before trying any of these, please please first contact your camera's maker or service provider. It will solve your problem quite easily.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind or if your camera is out of warranty and you can try some risky solutions.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 02, 2011 | Canon PowerShot A460 Digital Camera
The problem is that the camera cannot open the front eye, when you turn on the camera it does not come out. and at the end it say lens error, restart camera, but still do the same thing. help cause i want...
Its a common error with cameras with retractable lenses. It could be a grain of sand stuck in the slide parts of the lens. Another cause is accidentally pressing the ON button when the camera is in its case.
The solution is usually "helping" the camera lens to come out. This is a tricky job because it requires putting pressure (by pulling) on sensitive lens parts. If you're not comfortable with that, ask someone else to have a look at it.
I've had one IXUS 860 which could not be recovered from the lens error. The second IXUS 860 had the same error - the lens however moved finally after turning the cap for a bit. In the first case it was sand. In the second had tried to push the lens out while in its case - the ON button was pressed.
Jul 04, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Lens error; restart camera
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
"lens error please restart camera"
Hello!!
Remove the batteries and keep pressed the power button for few seconds it will reset ur system!!
Oct 21, 2008 | Canon PowerShot A470 Digital Camera
Powershotsd1000 problem
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Jul 19, 2008 | Canon PowerShot SD1000 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot A630 Digital Camera Logo
125 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
