Question about Nikon FE 35mm SLR Camera
Film speed selector stuck
The knob that you use to set your film speed is stuck at 3200 and i can't change it! The little lock release button will go down, but I can't turn the knob itself.
  • tommygunn789 Oct 12, 2008
    it still won't turn.
  • krravi Feb 11, 2009
    I have the same problem as above. It just wont budge. But the batteries in my camera are weak to none. But still i dont think that should cause this as its a completely mechanical device.
    Problem Solver:
  • 28 Answers
Try to rotate the lock body anti-clockwise. Do not use muscle power, just try to rotate softly the locking body.
Posted on Oct 11, 2008
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
I just bought a nice used Mamiya twin lens C3 but the shutter is locked up. There is a small metal piece holding the shutter release from moving. Not sure how to un-lock, seams to be a safety device of...
The vertical shutter sliding lever gets locked if the film doesn't get advanced to the next frame, and the mode selector is set for single exposure. You can't trip the shutter unless you have film in the camera and you forward the film to the next frame. That should allow you to release the shutter with the sliding lever.
Mar 17, 2014 | Mamiya Cameras
My 645 1000s shutter buttons wont pop back up.this is my 1st mamiya
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do:
1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red button just behind the shutter release button on the top right side of the camera.... drum roll please...."Push the red button" what you should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
Jul 12, 2011 | Mamiya Photography
How do i open the back cover , and what is the rewind crank ?
You open the back by pulling upwards on the rewind crank. The rewind crank is on the top of the camera on the left (as you look through the viewfinder) in the center of the knob that sets the film speed. The crank is folded into the knob. DON'T open the back until you have rewound the film. You will have to press a button on the bottom of the camera to release the film before you can rewind.
It will be a lot easier if you can get an experienced person to show you the first time.
Nov 21, 2010 | Minolta XG-A 35mm SLR Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Trying to get the film removed and new film put in
to rewind the film back into the tin look underneath the camera you will see a button, press this, it will disengage the winding mechanism, looking on top of the camera to the left you see a knob. flip out the handle and start to turn this clockwise until you hear a click and the turning become a little easier. if it is hard to turn, ensure the button undeneath is still pushed in. once the film is wound back, lift this knob this should open the back door and of the camera and release the spent film can.
take your new film and take it out if its platic container. place the old film in the same container for safe keeping til it goes to processing.
place the new film into the camera on the left side with the brown tab of the film laying over the shutter window in the middle.
press in the winder knob to help hold the film container in place.
pull out the end of the film and guide it over the two wheels with teeth ensureing that the teeth fit into the perferation holes in the film.
slide the film across the camera to the roller on the oposite side. slightly wind the camera on help guide the film tab into the slot
once in the slot slowly wind the camera on ensuring that the film is running smoothly over the shutter gate.
now close the back of the camera which should click to lock.
now wind on the film until the winder leaver stops
check the ASA or IOS rating of your film from the box it came in.
and ensure this setting is correct on the setting wheel on the right.
if your camera has automatic film recognition then this is not necessary.
you are now ready to start taking pictures again.
Nov 15, 2009 | Minolta X-700 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Instruction manual for settings on a Nikon F2?
Set the film speed with the dial on top of the Photomic unit. Lift the chrome ring and turn so that the film speed is next to the little red arrow.
Yes, the aperture is set by the lens ring. And if you have one of the older finders which uses the prong meter connection, whenever you mount a lens you must turn the aperture ring all the way to the highest number, then back to the lowest number. For old-timers, this is known as the "Nikon twist". It tells the meter system what the widest aperture of the lens is so that it can measure light properly at full aperture.
Yes, the shutter speed is set by the dial on top. The Photomic meter sits on top of it, so you read the shutter speed from the scale on the side of the Photomic dial by the mark on the back.
The other buttons on the front are the lens release button (left side as you hold the camera), DOF preview (button just under shutter release), mirror lock-up (lever ring around DOF button) and self-timer (long lever at bottom).
The T-L ring serves to protect the shutter release from accidental push. If you lift the ring and turn the mark to L, the shutter release is Locked. If you lift and turn to T, it prepares the shutter for Time operation, where the shutter remains open when released without holding the button down as you do at the B speed setting.
Finally, the most help: you can download the manual for free (donation requested, and worth it) at http://www.butkus.org/chinon/nikon/nikon_f2_photomic/nikon_f2_photomic.htm
Feb 08, 2009 | Nikon Photography
CAN WORKOUT HOW TO OPEN NIKON FE CAMERA
Sept 19th, 2008
On the bottom of the Nikon FE, there is a silver button to push in, and this releases a lock for the film.
Then on the left side, on the top, there is a white arrow and a silver lever tucked in. Wind your film, this it's all the way back in the canister. Then the black lever by the speed film (ASO) numbers, pull that back toward you. This will release the black 3/4" knob upward, and by gently pulling this upward, your door will release and the film canister will be allowed to come out. Just besure to wind your film back in the cansiter, before you open the door, or your photos will be over exposed. Best to do this in a darker area or shaddowed area, just for protection.
Good Luck. I've had mine since the mid 1970's and love it for double exposures and the special filters I have for it. The Hot Shoe for the flash attachment, just burned out on me a couple of days ago.
Mar 02, 2008 | Nikon FE 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
78 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
