Question about GE JKP45 Electric Double Oven
GE JKP45 Electric Double Oven Front Panel
The digital panel on my JKP45 Double Oven will not come on. I turned the circuit breaker off & on, but no help. The upper and lower oven lights come on but there is no response from the digital panel. Any suggestions on how to resolve the problem?
  • 1 more comment
  • rsnyder309 Nov 07, 2008
    Mine comes on and then goes off. If yo slap the panel it comes back or if it cools.
  • gaherty Nov 15, 2008
    Same as above. Panel to JTP45 will not come on. Breaker seems to be fine - although have not taken it totally out of the breaker box to see the back wires. The light in the 2 ovens do come on.
  • awhite621 Dec 28, 2008
    Same problem. Seems to have happened after I ran the self cleaning cycle. Top works fine, bottom wont turn on.
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
Powerman
  • 68 Answers
SOURCE: Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Posted on Aug 09, 2007
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
Neither oven will heat when start is pressed, get a clicking sound from panel, temp stays at 100 deg.
Check for 220v as 110v will give one leg of power but not both. your breaker. or your control board is faulty.
Sep 03, 2012 | GE JKP45 Electric Double Oven
My GE JKP45 double oven needs a new control panel (part # WB27K5047 which is no longer available) There are a few place I've found on-line that refurbish electronic panels, or if it only has a loose...
according to the website i use to look up part#s while the part# you have is indeed not available a replacement for it is WB27T10050
to removeand replace it unscrew the screws that hold it to the cabinet pull it out about 4-6 inches,remove the grill directly under the control panel on the upper oven and look for screws around the panel where ya have pulled it out of the cabinet
to see yourself the replacement part# go to searspartsdirect and enter the model# and you will see the eoc (electronic oven control) as item #16 under the control panel and top tab
Jul 20, 2011 | GE JKP45 Electric Double Oven
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
Oven is display F-1, what the problem? Model JKP45
Hi
Thanks for using FixYa. Error F1 in your GE Electric Double oven means that the control panel has gone bad and to resolve this issue it should be replaced. Unfortunately there is no other way it can be resolved. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 23, 2010 | GE JKP45 Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
Cant read control panel. LED is very dim JKP45
Ordered a new panel . Control panel is not serviceable
Oct 12, 2009 | GE JKP45 Electric Double Oven
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
General Electric JKP45 Double Oven
Don't know why repairman couldn't order parts you have your model #. The model # is the JKP45WV1WW, The part # is WB26K5030 for the lock motor.
Jun 30, 2008 | GE JKP45 Electric Double Oven
Aug 09, 2007 | GE JKP45 Electric Double Oven
F1 code on my Oven
You have a bad control module.
Jun 04, 2007 | GE JKP45 Electric Double Oven
GE JKP45 Electric Double Oven Logo
42 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
