No disc error message - Televison & Video
  • BIGMAMA43 Dec 17, 2008
    i HAVE THE SAME PROBLEM BUT i DONT THINK ITS THE LENSE BECAUSE THIS IS MY THIRD ONE AND IT ALWAYS HAPPENS AFTER MY NEPHEWS LEAVE SO THEY ARE DOING SOMETHING TO IT TO MAKE IT HAPPEN AND I THINK IT HAS SOMETHING TO DO WITH THE FORCE THE DOOR SHUT WHEN PUTTING IN A DVD IN STEAD OF USING THE REMOTE OR BUTTON.
  • 19,396 Answers
When that happens, often that means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
If that does not work, you will need to take apart the unit, access the lens pickup, and clean the lens directly, using isopropyl alcohol and a cotton sticks.
Posted on Oct 10, 2008
Error message 03-354 on Sony PDW-510. What is it?
You may be using a disc that isn't compatible with the camera. This message appears if you put a 50 GB disc in a camera that can only use 23 GB discs. The error will not clear until you put the right disc in.
Apr 11, 2011 | Sony PDW-510 Camcorder
Error message: "disc is unredadable", this is new
Here is the Microsoft solution page for this error. Try steps 3, 4, and 5.
Mar 09, 2011 | Microsoft Xbox 360 Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
Our wii send an error message saying it can't read disc
i had the same problem with my wii. I called nintendo and then had to ship it back to get repaired.
Feb 11, 2010 | Nintendo Wii Console
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Wii will not play any of my games discs
Made a video showing how I fixed this exact problem on a Wii.
Mar 20, 2009 | Nintendo Wii Console
Recovery Error
Do recovery again, when it asks you to insert disc 2, take out disc one and close the tray. Do not put the disc 2 yet. If you can see the error message again, then it is a RAM issue. You need to reseat the Memory module and try to do the recovery again.
If you closed the tray then no error message came up, it would be an issue with your recovery disc and order for a new one. You can contact Toshiba to have the recovery replaced due to corrupt media.
Hope this helps.
Sep 12, 2008 | Toshiba Satellite A105 Notebook
Televison & Video Logo
500 people viewed this question
Top Televison & Video Experts
Electro Med Services...
