Question about Vtech Lands Phones
My child messed up with my telephone, and I got problem with the answering machine. I can't go into answering machine by using my password, I cannot delete messages, and I cannot have access to my answering machine from outside. SO PLEASE I NEED YOUR HELP IN RESETTING MY ANSWERING MACHINE WITH A NEW PASSWORD AND ALSO MAKE IT WORK.
  • 51 Answers
Switch off for few minutes and then try again your password it would work definitely.......
Posted on Oct 11, 2008
What is your first child name?
this sounds like a typical security question for a web site usually used for when you forget your password
it is asking for the name of your oldest child so when you forget your password and ask to be reminded of your password they can ask a question you should only know the answer for.
Mar 22, 2016 | Computers & Internet
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
How do I receive a fax?
if the telephone cord is plugged in, all you should need to do is have someone send a fax.
unless you are sharing the phone line with your telephone and answering machine.
sometimes the answering machine may try to answer first and mess it all up.
Jan 04, 2011 | HP J3680 Officejet All In One Printer
Answering machine leaves the telephone line open
Chances are it did not damage the control(operating) curcuits, but most likely the Telephone curcuits in the answering machine.
Aug 11, 2009 | GE 29869GE2 Digital Answering Machine
#1739 answering machine hooked up but keeps asking for "password"
The unit appears to be stuck in "message retrieval mode) and is asking for your password to give you access when you call in(remote answering). You need to return the unit to it's factory default settings. If you don't still have the instructions you can get them here:http://telephones.att.com/docMgt/public/art/309494/1739_manual.pt2.pdf. Hope this helps!
Mar 28, 2009 | AT&T 1717 Digital Answering Machine
Static
If the telephone line itself is static-free, connect a normal telephone to the same jack that the answering machine uses. If all calls are static-free, you've cleared the wiring and the telephone service provider. Next, plug the telephone into the jack on the back of the answering machine. If all calls are clean, but messages are still loaded with static, then we may be talking about a bad answering machine. If you have DSL service, make sure that there is a filter installed between the wall jack and the cord that goes to the answering machine.
Dec 03, 2008 | AT&T 1738 Digital Answering Machine
I can't figure out how to set up my fax machine so it won't mess up my phone and answering machine either.
Telephone wire goes to fax, out to answer machine, Important to set fax on answer machine mode and set the ring count to pick up AFTER the telephone answer machine. Set fax ring count to 5 rings, and answering machine to 3 or 4. When some one calls answer machine or you pick up first, then if no one will leave a msg. fax tones are different than voice tones, they are called CNG tones. Most new fax machine will sense this and if a fax will go to fax only. Ring count is the key. Also you could set fax up for maual mode and would not jump to anser machine or fax till you want.....good luck
Aug 28, 2008 | Office Equipment & Supplies
Lucent Digital Answering Machine Model 1715
If you search for an AT&T Digital Answering machine model 1715, you will be sent to a free service with an abreviated manual.
Oct 08, 2007 | Lands Phones
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
Lands Phones Logo
149 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
