I HAVE BROUGHT A SECOND HAND IPOD NANO BUT IT CAME WITHOUT AN INSTALLTION DISC AND MY COMPUTOR WILL NOT PICK IT UP
Sorted
Posted on Oct 11, 2008
My Ipod nano has frozen. I have plugged it back
try holding menu and center button for a couple seconds
Jul 09, 2009 | Apple iPod nano
I own a 3rd gen ipod nano. When I hooked it up to
You will want to force the iPod into disc mode before reconnecting to your computer for the restore process within iTunes. Below is a step by step on forcing an iPod into disc mode just in case you need the information.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 24, 2009 | Apple iPod nano 3rd Generation
Delete songs from my music file from my computor
Below is a URL that you can copy and paste into your browser bar. It will take you directly to the iPod manual that will teach you every thing you need to know about syncing and deleting content on the iPod. :)
http://manuals.info.apple.com/en_US/iPod_nano_4th_gen_UserGuide.pdf
Apr 12, 2009 | Apple iPod nano
I cannot install music from my computor to my Ipod 4 nano
If you can't connect iPod nano to your computer , make sure;
  • you have installed the latest iTunes software from www.apple.com/ipod/start.
  • Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
  • iPod nano might need to be reset (see page 64).
  • If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
  • Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
  • Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
  • Try restarting your computer.
Mar 11, 2009 | Apple iPod nano
Ipod nano 3rd generation wont connect with windows xp
I have the same ipod and had the same problem - I ignored itunes and the computer and went to "real player" and treated it like an mp3 player and in real player you pick your music you want to burn to a cd but go to "device" column and change the destination from burning to your internal cd burner to the external drive which is the ipod and it downloaded perfect! hope this helps
Sep 11, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Lost disc
theres no software disc for ipods.
if youre talking about installing itunes, you can go the the website. (apple.com)
Jul 02, 2008 | Apple iPod nano 3rd Generation
Ipod Nano 3rd Generation volume problems
Finger the clickwheel counterclockwise to turn the volume down
May 29, 2008 | Apple iPod nano
Ipod nano 3rd gen
It's in disk mode and the computer thinks that it is only a storage device. You need to reset it to get it back to normal.
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 27, 2007 | Apple iPod nano
You can only sync an ipod with itunes software, it doesn't come with the ipod though.
Go here:
http://www.apple.com/itunes/
On the right hand side it says itunes 7 Download now. That's the software you need to use with an ipod.
Dec 25, 2007 | Apple iPod nano
My Ipod Nano Won't Respond
The problem may be battery charge. Leave it plugged into the computer for 6 hours, and then try it. If this does not work, the best thing to do may be to call apple for further help.
Nov 17, 2007 | Apple iPod nano
19 people viewed this question
 Grubhead
Grubhead
