Question about Cell Phones
displaying on phone screen
My phone is still displaying the words on the main screen and therefore is not allowing me to use the phone as normal.
  • 1,031 Answers
Have you tried the steps i gave you?then try the try the extended hard reset ,remove all source of supply and leave it for 30 min before putting it back. hopefully it will work then i will tell you what next.goodluck and godbless
Posted on Oct 11, 2008
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
My hp lcd monitor screen is accidently suffered a pin hole. how to plug this pin hole to make screen normal and prevent white light from escaping from screen and read words on that part of screen which get...
LCD is Short for liquid crystal display, a type of display used in digital watches and many portable computers. LCD displays utilize two sheets of polarizing material with a liquid crystal solution between them. An electric current passed through the liquid causes the crystals to align so that light cannot pass through them. Each crystal, therefore, is like a shutter, either allowing light to pass through or blocking the light.
If you have a "hole" in it then you will most likely have to replace the display.
Aug 29, 2013 | HP Computers & Internet
Parrot ls3200 displaying goodbye
Good bye appear when the car kit switch off. Then suppose to be in relation with the question of the 12 ignition. If it doesn't disconnect of switch off in relation with the car, maybe the kit has a 12 DC and not an ignition connected.
If you can disconnect the power supply of the kit, just do it, and it should normally coming back to the main screen.
Mar 20, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
I have a LG vx 5200 that displays the words "Car Kit" after getting wet
Take your phone apart, an using a soft toothbrush clean the CN302 connection at the base of your phone, next to the connector there's a U204 IC with identinfication AAD1 on it. Those are the main areas that needs to be cleaned. For better results you can use a bit of NON-alcoholic cleaning detergent. This will solve your problem.
Best of luck
Jun 27, 2009 | LG VX5200 Cellular Phone
One click carousel missing
back up your contacts and do a full reset on your phone.
Apr 15, 2009 | Samsung Rant Cell Phone
Removing words from main screen
I would say you would need to go in and change your settings. If you have an option to have a screen saver or not, that would probably be where you can change whatever comes up during idle mode.
Aug 30, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Nokia K750i
If the new screen is white and old screen displays 20% of the display then you can check by flashing the software , in most the cases white screen is the software problem.....
Aug 17, 2008 | LG M4410 Cellular Phone
Car kit on display screen
It's actually something wrong with your phone. The connector on the bottom of the phone may have gotten wet. If you are comfortable taking the phone apart you can clean the connector w/ 99.5% isopropyl alcohol and a soft bristled brush. Good luck.
Sep 05, 2007 | Cell Phones
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
