Question about Garmin GPS
When I turn on my Garmin Nuvi 260, I get this message: "No detailed maps found that support routing. The Nuvi cannot be used without them." What can I do?
  • 1 more comment
  • lwiegand Oct 10, 2008
    I uploaded the latest updates for the Garmin Nuvi 260.
    I also touched the message screen with "No detailed maps found that support routing." about 100 times with no result.
  • lwiegand Oct 11, 2008
    I found the solution in Garmin's FAQ's. The map unlock file wasn't loading (gmapprom.unl).
    Here's where the solution is located:
    http://www.garmin.com/garmin/cms/site/us...
    Thanks to all who responded to my problem!
    Sergeant:
  • 399 Answers
I suspect the long delay occurred after a firmware update. Sometimes the Nuvi's memory needs to cleared after a firmware upgrade that changed the address map. Please backup any user waypoints and custom POI then:
just do a hard reset..push and hold the reset button on the back of unit just under your open antenna.
how to get to a system info/diagnostics screen set for Nuvis
When you're at the main screen, hold your finger on the time in the upper right corner for more than 5 seconds, and you'll get to an info screen, and back/next buttons lower right of screen.
There's some sound diagnostics, and screen tests, and lots of info pages - including one with some battery status/statistics. To get out of the diagnostic mode, power cycle your unit...and when you do this, it will take some time to lock on to satellites.
go to this link and check the procedure of making your garmin device proper as it will definately work.the persons facing the same problem like you got it fixed and you can also fix.
just click this link
http://www.poi-factory.com/node/11744
thanks.
Posted on Oct 10, 2008
  • 3,037 Answers
Try resetting the device. the outer panel that goes around the screen should lift off and a reset button will be found underneath. Try pressing the button and then redownloading the maps and let me know how that goes
  • Benjamin Patri
    Benjamin Patri Oct 11, 2008
    no problem, glad you were able to fix it, have a great day and let us know if you ever need anything else
  • 282 Answers
Well, since you seem to be missing the gmapprom.img file which is the pre-installed detail map file and since you don't have a backup file, Tech Support is your only option. They will likely have to send you a disk with the maps for you to reload them. The maps are too large for downloading via the internet. (Hopefully, they won't ask you to send the unit to them.)
Note to all users:
1. Before doing anything on your unit, BACK UP the entire thing to your computer. It will take 30 - 45 minutes or so, but as you can see, it's worth it.
2. Before deleting or otherwise manipulating ANY files on your Garmin unit, BE SURE that you know exactly what those files are.
Simply loading and unloading Custom POIs with POI Loader will not delete the map files on your GPS unit. This is something that the user does, albeit most likely inadvertently. Having a backup is your extra protection, but still users should be sure that that they know which files are which.
    President:
  • 2,712 Answers
Have you tried to download the latest updates form the Garmin website?
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson Oct 10, 2008
    From Garmin website:
    The "No Detailed Maps That Support Autorouting" message could be due to following reasons:
    • The GPS unit is missing the unlock file.
    • The maps on GPS unit has been disabled.
    Please follow these steps to troubleshoot the error message:
    Checking the unit:
    1. Touch the screen until the message “No Detailed Maps That Support Autorouting” disappears.
    2. If you get a locked maps
      message following this error please remove any SD cards in the device
      and follow the instructions for “Getting your unlock codes”.
    3. If you do not get the locked maps message then skip to instrcutions for"Enabling Maps on the GPS unit".
    Getting your unlock codes:
    1. Log into your myGarmin account using the linkhttps://my.garmin.com/mygarmin/customers...
    2. Click on myMaps.
    3. Click on Manage Maps.
    4. Manage Maps window will have your unit(s) and its unlock code listed.
    5. Copy all unlock codes for your the device with the error message.
    6. Open the Notepad application and paste the unlock code.
    7. Save the file on the desktop as GMAPPROM.UNL and type as text document.
    8. Close the document.
    9. Right-Click on the GMAPPROM.UNL document located on the desktop and select Copy.
    10. Plug your Garmin device to the USB port.
    11. Double-Click on My Computer located on the desktop.
    12. Double-Click on the Garmin/Nuvi drive.
    13. Right-Click on the Garmin folder and select Paste.
    14. Safely disconnect your Garmin device from the computer.
    15. You should no longer get the locked maps message.
    Nuvi 270/370/670/770 owners:
    Owners of these units will need to create 2 unlock files.
    1. Create first file for City Navigator North America NT maps with the filename GMAPPROM.UNL
    2. The second file for City Navigator Europe maps with the filename GMAPPROM1.UNL.
    Enabling Maps on the GPS unit:
    1. From the Main menu, touch the Tools(wrench) icon.
    2. In the upper left hand corner of the screen, touch Settings.
    3. Scroll down to Map.
    4. Touch on Map Info.
    5. Touch the checkbox to enable the Maps on the GPS unit.
  • Swilin Sampson
    Should you have any further questions, please post them
    here.
    If you are satisfied with my solution or have no further queries, please take a
    moment to "Accept" this solution.
    Thank you for using Fixya!
    Cheers!
    IrishDruid
  • Swilin Sampson
    You can also try a reset:
  • Swilin Sampson
    Swilin Sampson Oct 11, 2008
    Thats exactly what I posted. Fine way to thank the effort by giving a Thanks For Trying rating...
3 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Posted on Feb 28, 2009
sharcnet
  • 2124 Answers
SOURCE: Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Posted on Aug 20, 2009
Please connect your Nuvi up to a PC and look to see if you have the map file "gmapprom.img" in the Garmin directory. The file should be around 1.5 to 2 GB in size. If the file is missing you will need to replace it. If you have registered your unit with Garmin, you may be able to log into your Garmin account and download the map file again. If you can't, then you will need to send the unit to have the map file restored by a service shop. More info on missing maps can be found here:
http://www.sharc.net/gps_lost_map.htm
Apr 15, 2013 | Garmin nuvi 205W GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
When I turn on my nuvi 200 I get the message "no
If you got the unit from somebody they could of used a SD card and its looking for it and the ynever switched back to the regular map... to check try this..
Settings ... Map.... on he bottom of screen you will see Map Info .. press it.... it should now say what map is loaded on the gps...
It should have a checkmark in the City Navigator North American NT, if not put one there
Nov 04, 2010 | Garmin nuvi 200W GPS Receiver
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
NO DETAILED MAPS FOUND
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
May 10, 2009 | Garmin nuvi 205 GPS Receiver
No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
GPS Logo
125 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
