Question about Kitchen Ranges
2 year old ES340 Frigidaire Range - BROILER ELEMENT BLEWOUT -- BIG POP -- REPLACED ELEMENT BUT NEITHER OVEN OR BROILER ELEMENTS WORK
I have looked at the unit and replaced the element and I have noted that there is no TOD (Thermal Overload Device). Also, schematic provided with the unit show no fuses. I traced the wires and it appears that the elements only attached to the Electronic Oven Control. The EOC will cost $135 to replace, and a technician just to come out to see it will cost $130 plus parts so the total bill would be $265.00. Could not get extended warranty because unit is in a rental - and the limited warranty that covers 2-5 years only applies to the ceramic top and its elements. It appears that this is a simple replace of the EOC - but what caused the broiler element to blow - maybe an electrical surge - it so maybe the EOC can be fixed by replacing a blown contact - but that would take working with soldered on units and without any schematics of the EOC. What should I do. I have a degree in Electronics so I now how to be safe and how to use a VOM. Do you have any test point data for these EOC's. This seems like a costly repair and the broiler element already cost about $90.00. So all told the repair of a two year old unit will cost around $225.00 if I do it or $355.00 if a technician is called.
What advice do you have?
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
  • 1073 Answers
SOURCE: Frigidaire Gallery Series
the control is bad and will have to be replaced, nothing need to happen for the eoc to fail i see them fail new out of the box
Posted on Apr 12, 2008
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
  • 172 Answers
SOURCE: Amana electric range - light but no heat
Hi rablef,
I would recommend you check your fuse or breaker box for a blown fuse or tripped breaker. If you are only getting one leg of your 220 volts the you will have the problems you have listed. If you have no breaker or fuse problem you should then check your range cord for possible shorts or hot spots. Then work your way to the terminal block on the range. It definately sounds like you are only getting 110 volts to your range. I hope this will FixYa.
Good luck, Mike
Posted on Sep 24, 2008
MNTECH
  • 1543 Answers
SOURCE: Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
Posted on Nov 08, 2008
Repair or buy new oven.
replace the element....they are not that expensive.
Jul 20, 2010 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 22, 2009 | Kitchen Ranges
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
May 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Feb 09, 2008 | Kitchen Ranges
Kitchen Ranges Logo
231 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
