Question about Car Audio & Video
I have a woofer with only one negative and one positive hook up. However, the stereo I am trying to hook up (blaupunkt cd 127) has 2 negatives and 2 positives. How do I hook up the woofer to the stereo?
    Problem Solver:
  • 13 Answers
Just use one ngative and one positive, tape over the ends of the other 2 wires if they are not rca's
Posted on Oct 11, 2008
How do I wire a pair of type r 15 inch woofers to 2 pdx 1.1000 amps for maximum bass output
are u trying to run one speaker of each amp if so the should be dual voice coil jump one positive to the opposite side negative then take the positive thats not hooked up from one side and the negative thats not hooked up from the other side and run them to the amp but turn ur amp down all the way and work it up because one speaker will not handle all the power from one amp
Mar 30, 2012 | Alpine Car Audio & Video
Problem with installing a new cd player , wanted a wire colour I D chart or diagram for Subaru outback, 96 model.
Do the below colors match what you see?
1996 Subaru Outback Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Green
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
Aug 25, 2011 | Car Audio & Video
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
I have a power acoustik 0V4-1200 amp and 2-12" kicker cvr dual 2 ohms. My amp keeps getting really hot and turning off. I have two pair of rca jacks from my cd player to the amp. One speaker hooked up...
i have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Feb 07, 2011 | Car Audio & Video
There are 2 input ports on the sub woofer. How can i connect them to mono amp
subs usually allow a bridge where you connect the mono positive to one side positive and the mono negative to the other side negative. Does it not mention this in the instructions? If you don't have the instructions, try it. It can't hurt anything, but use low volume when checking. If you want to verify the bridge before hooking up, use an ohmmeter to look across the positive on one side to the negative on the other. If one combination is open or more than 8 ohms, try the other set of positive and cross-negative. OK?
Dec 01, 2010 | Pioneer C-Type TS-W306DVC Car Subwoofer
Need wiring diagram for 92 dodge caravan tryin to install cd player
Here it is
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Antenna Trigger Wire: Yellow
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Yellow
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 14, 2010 | Car Audio & Video
Alpine sub woofer
your speakers are hooked up wrong. hook both positives together and both negatives together and bridge it to the amp. if it is one channel hook it up as one together. if it is 2 channel hook positive to one side and negative to the other side.
May 18, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
I dont know which wires are which in the dash of a 1987 dodge dakota
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black/Yellow
Left Rear Speaker Negative Wire (-): Gray
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
May 04, 2009 | Car Audio & Video
My solo kicker isnt performing right
do both voicecoils work? try one at a time...then if they do....get a piece of speaker wire about a foot long...connect the positive to the positive and the negative to the negative...then hook the wire from the amp up to one voicecoil....
Jan 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
