Question about Venturer PVS177W Portable DVD Player
VENTURER PVS6281 I HAVE AN INVERTED DISPLAY ON MY VENTUER 6281 DUAL SCREEN DVD PLAYER. BY INVERTED I MEAN LIKE LOOKING AT A MIRRORED IMAGE. IT IS ONLY ON ONE OF THE SCREENS. THANKS FOR ANY HELP TONY
Noggin
  • 944 Answers
SOURCE: ventuer pvs 1262
a new battery sounds like the solution. Here is the link to the manual; http://www.1800customersupport.com/productdocuments/PVS1262.pdf Link for troubleshooting FAQs; http://www.1800customersupport.com/products.aspx?view=36&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders this next link will give you contact details in order to source a new battery, but try them first in case they know another solution; http://www.1800customersupport.com/request.aspx Hope this helps, post again please if not :)
Posted on Mar 22, 2007
Noggin
  • 944 Answers
SOURCE: DVD not recognized
Try this link for user manual, troubleshooting and venturer support contact; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders I assume you have tried other dvd's with the same result? Hope this helps :)
SOURCE: Venturer PVS6281 - Playing One Disc on Both?
the red, yellow,white cables connect them to both of the dvd players.One of them the little switch on the side put one on dvd and the other one on av in. then put a dvd in one and play it. (make sure both are on)
Posted on Jun 22, 2008
SOURCE: Venturer Portable DVD Player, twin 8" Screens, PVS6988
I manage to get the manual from Venturer. Google it. I am in UK and I have to phone them and than get them to send the manual by pdf to my email address. No charge. Easy.
The older ones are not on their listing.
If you have any problem come back to me and I will look it up for you.
Posted on Feb 23, 2009
SOURCE: Black screens, set checked everything but can not
i have a portable dvd venturer pvs 1262 / no manual for troubleshooting. when i plug in the ac adapter the red light turns on, then the green light turns on. but then will immediatly turn off. i can see the screen start to light up..but still no screen.. the dvd disc will not spin at all. can you give me any troubleshooting advise. or a site that can help me? thankyou in advance
Posted on Jun 18, 2010
I have an audiosonic dual screen dvd player model TDV-79FB8 - I've attached the cord to the second player but I am unable to get an image or sound, just a blue screen. How do I fix this?
uhm, if you're sure that you properly connected the cables... that means that you have to set your tv on the right input. if you're using an HDMI cables,
Oct 16, 2016 | Dual Televison & Video
One screen is blue but the DVD will play you can hear the movie but no picture on the screen
open the cover the dvd player,try to check connector from mother board thru lcd,if loosed connctor.
Mar 11, 2010 | Power Voice System Venturer 7" Portable...
No picture on dvd player but can hear sound
Usually this is a bad inverter. The best way to check this is to hold the unit up to a very bright light and see if there is a ghost of am image visible and moving, just not bright enough to be seen properly. This means that the display is working, but the flourescent display behind it is not being powered properly, and most LCD displays require a little inverter board to convert the native DC power to AC to light the backlight. inverter boards are cheap if you can find the proper one for your unit. Unfortunately some units have the inverter board integrated into the motherboard of the player, though that is rare. It should be a separate (and thus replacable) component. Good luck!
Dec 01, 2009 | Toshiba SD-P1400 Portable DVD Player
The only "kill switch" I am aware of is the switch on the DVD compartment door. I don't have your exact model but, on my model, this switch is activated when the door covering the DVD is closed and deactivated when this door is opened (kills the DVD spin and reading laser). Look for a small square hole in the DVD player deck and a corresponding raised piece of plastic on the DVD door.
Oct 07, 2009 | Venturer 3.6" Portable DVD Player
Venturer dual screen dvd player for car
Hi and welcome to FixYa,
Initially, could be:
  • cable/connector problem;
  • 12VDC power supply/regulator;
  • monitor itself. Could be tested with another external video source and a shorter RCA to RCA cable.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 11, 2009 | Power Voice System Venturer 7" Portable...
Jun 14, 2008 | Venturer PVS62911 Car Video Player
Dual Screen not working
I`M TRYING TO HOOK UP THE OTHER SCREEN THE DVD PLAYER PLAYS FINE BUT I CANT HOOK UP THE OTHER SCREEN TO IT HOW DO I HOOK IT UP
Aug 13, 2007 | Power Voice System Venturer PVS1988...
Ventuer pvs 1262
Mar 22, 2007 | Venturer PVS177W Portable DVD Player
DVD not recognized
after loading it say no ddisc
Mar 20, 2007 | Venturer PVS177W Portable DVD Player
Venturer PVS177W Portable DVD Player Logo
198 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
