I have a HP Color LaserJet 2550n printer and the Magenta cartridge has totally run out. The carousel is not rotating when I press the button so I cannot get to the Magenta cartridge to replace it.
  • 4,338 Answers
Rotate the print-cartridge carousel manually:
Turn the power off and un-plug the power cord.
Open the top cover
press the end of a paper clip into the guide (callout 1) to lift up the carousel brake.It's on the right handside
Then you can rotate the carousel manually.
I have a picture I can email to you if you need it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 10, 2008
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
The light before the print cartridges is lit up. What does that mean?
I'm not following your very brief non descript description.
But I'll try.
The Print Cartridge lights are at the top of the control panel.
The bottom button is the Rotate Carousel
Now below that is the IMAGING DRUM light
Now if you meant to write "below' instead of before, then we are in business.
If that light is Blinking it means that the drum is empty or missing.
Replace the drum
Jan 20, 2011 | HP LaserJet 2550n Printer
Printing Hp Laserjet 2550n
there is a clutch that stop/release the movement on the carousel,is located on the top right part of the carousel. remove and clean the STICKY CLUTCH.
Reinstall and ready to work
Mar 09, 2010 | HP LaserJet 2550n Printer
HP 2550n -rotating the imaging drum backwards?
There is a locking mechanism that actuates when the front door is opened. This is a safety device, and should only be tampered with if you know what you are doing. Also, make sure you unplug the mains power before proceeding.
Having given you air warning, proceed at your own risk...
If you look up near the RHS door hinge there is a slot for the safety interlock. Use a small screwdriver to push the locking lever toward the rear of the device. The Carousel should now rotate by hand
There is a fairly common fault with this model involving this mechanism. It may need the lock and associated mechanism replaced
Be careful and Good Luck...
Dec 07, 2009 | HP LaserJet 2550n Printer
How to change toners
Open front door, check on the color facing you, close door, press the color cartridge to advance the carousel to the color you need to replace, pull out the cartridge and replace with new one.
Jan 13, 2009 | HP Color LaserJet 2550n printer + HP Color...
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
Replaced toner but keeps saying replace supply using black only
This happens occasionally with after-market (refurbished) cartridges. Sometimes the people rebuilding the cartridges forget to replace the microchip on the cartridge that resets the copy counter. Most reputable re-manufacturers will send you a replacement cartridge if this happens.
It could also be a carousel alignment or sensor issue inside the printer - if this is the case you will have to call HP for service.
Whatever you do, make sure you do not try to manually rotate the carousel to change out the different cartridges - each time you want to change a specific color, close up the printer first and then press the carousel rotate button that's directly under the ready light, keep pressing until the display says that it's rotating to the color you want, then open and change that color, repeat for each additional color.
Oct 13, 2008 | HP LaserJet 2840 Printer
Hp lazerjet 2550n
Your Black cartridge is empty.
From the user guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
Here is a link for the User Guide:
2550n User Guide
If this solution has been helpful, please take a moment to rate it. Thanks!
Jun 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Black replacement cartridge
This is an easy one, you do the black the same as each color cartridge. All four cartridges sit on a carousel that rotates.
Just keep pressing the button that's directly underneath the ready light until it says "rotating to black". After the machine stops rotating, open up the cover and put the black cartridge in.
Apr 03, 2008 | HP LaserJet 2840 Printer
HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Dec 29, 2006 | HP Color LaserJet 2550n printer + HP Color...
352 people viewed this question
jasbo
jasbo
