Question about Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite won't boot up
Hey..i need help! my laptop won't boot. it gets past toshiba screen then as windows tried to load, it freezes. i am currently using it in safe mode and it was fixed for a little by an IT guy who said it was boot processor? is there a way i can fix this problem? it's only 15 months old!
  • pbrady325 Oct 11, 2008
    already tried the reformating with the discs and that didn't work, and unfortunately i didn't kno i could run it in safe mode and get my stuff!! :( should i try reformat again?
    i will try a reformat again, it probably was boot process, it seemed simple as he was done with computer quickly. thanks a lot! :) i'll be back on hopefully. and unfortunately i have windows vista which is a problem in itself :)
  • 71 Answers
While you have it in safe mode, make sure you back up all your personal data to a cd as is sounds like it is not going to last much longer. After you back up all your information....Documents, Pictures, Music...etc... Then I would reformat the machine with the original installation disc that came with the computer. That should fix the problem. Never even heard of a boot processor :)
Posted on Oct 10, 2008
  • compgeek09 Oct 11, 2008
    Yes I would try to format the machine again. When you say that the IT guy told you there was a problem with the boot processor, I am guessing that he meant to say boot process, which is just a setting in the bios that tells the machine which order to boot from such as boot from cd or boot from hard drive. If you are able to format the machine from the CD then it sounds like it is booting in the proper order. Are you using XP home edition? Try the format again and then let me know what happens.
    Thanks
My laptop is lit up but cant go any further
Wdk, Try starting up in safe mode and use system restore to go back to an earlier date when PC ran OK, an update or virus may have corrupted the start up. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Windows is loading files then blank screen
http://ccm.net/forum/affich-108275-toshiba-laptop-cannot-reach-login-screen
My Toshiba satellite cannot load anything at all Windows 8 and Windows 8 1
http://forums.toshiba.com/t5/Windows-7/Windows-7-won-t-start-black-screen/td-p/157700
Aug 27, 2016 | Toshiba Satellite Computers & Internet
Can't get Toshiba Satellite L775 to boot past "windows is loading files" screen
I assume you are doing a System Restore/Recovery? Have you removed the HDD and tested it? Perhaps the Recovery files are corrupt/missing? A bit more info needed.
Jul 03, 2013 | Toshiba Satellite L655-S5160 Laptop PC...
Toshiba wont boot
From the description your hard drive is the issue, have it tested to see if it must be replaced.
Jul 08, 2012 | Toshiba Satellite L305-S5875 Notebook
Hi! I've got a Toshiba Satellite L300 and it won't boot anymore. I get past the initial toshiba-screen where I can press F2 and F12 but afterwards there's just a black screen with a little...
You can retrieve your data by removing the hard drive and connecting it to an USB hard drive adapter then plug it into the USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and files to back up your data.
You can then return the hard drive back into the Toshiba then format the hard drive and reinstall Windows to get your Toshiba working again.
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Jul 05, 2011 | Toshiba Satellite Pro L300 Notebook
MY TOSHIBA SATELLITE PRO LAPTOP WONT GO PAST THE WINDOWS XP LOGO SCREEN AND HAS BEEN FROZEN LIKE THAT FOR HOURS BUT THE LOADING BAR IS STILL MOVING
Hi Good day!!! Try to boot in safe mode, to boot from safe mode, do this: while booting just keep pressing f8 button until advanced boot menu appear after that choose safemode. after that your OS will boot in safemode. if not booting there should be a files missing in your OS you will need to repair it using a CD of you OS. reply to me to help you more
Thank you for using FixYA
Please accept if my solution helps you
Nov 24, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop boots up but after nothing.
Hard drive is shot. replace and then re install operating system
Jul 05, 2009 | Toshiba Satellite M45-S265 Notebook
Loading problem
I take it you see the hard drive when you boot to vista cd. doing install can you remove partition and then create new partition format and install vista software. have you tried that if so sounds like your hard drive is working and can delete and reset drive partition index. if your crashing in post then you need to push the tab key when toshiba logo appears should switch showing post BIOS boot on screen all text you should try pressing the setup key as soon as you see the num loc light blink on your keyboard the driver is loaded press f2 then tab key to check post boot.
please let me if this helped you.
Mar 21, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Jul 26, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
366 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
