There's a strong smell emitting from our water heater - so strong i first smelled it sitting in the lounge - about 4 metres from the balcony where it's fitted (door open). smells very strong around the unit. it could be a gas leak? is this dangerous? should i switch off the plug/tap? and is this fixable? all advice appreciated! thanks
SOURCE: rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
SOURCE: Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
SOURCE: Bad gas smell when heater is operating
I would call him back out. It sounds like a gas line is loose or the vent is not on properly
SOURCE: Dip switch settings for Rinnai V1200 & V1500
curios to find out if you had any help on this subjuct at all?
SOURCE: How to operate Rinnai V1500
The V1500 is in essence the same as Infinity 26. Rinnai have manuals on their website.
Here's a link
http://www.rinnai.com.au/images/stories/operating_instructions/Hot_Water/All_Continuous_Flow.pdf
If you have any specific problems or queries just post them on this site. I check it every few days.
Cheers
