Windows cannot read from the source
Hello everyone:
I have the following message when I am trying to open a DVD:
windows cannot read from the source. the source might be corrupted or it could be using a format that is not compatible with windows.
Thanks.
    Genius:
  • 1,124 Answers
Try to cleaning the DVD surface. If not work the DVD is corrupted or not compatible - Try to open the DVD using another program instead of Windws media.
Posted on Oct 10, 2008
  • Pablo Csaky
    Pablo Csaky Oct 17, 2008
    Thank you for using FIXYA!
    Dont forget to rate my help!
    Have a great day!
    Pablo :-)
    Let me know if you have further questions about this issue.
How do I repair a corrupted CDR file?
try the following:
- rename the file to ".zip "
- open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
- try to repair the file
- then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
These steps work for me.
Or try use CorelDRAW Repair Kit. CorelDRAW file repair software for recovery of the contents of damaged CDR files. Program helps to repair corrupted Corel Draw project files.
Corel Draw repair file
Jul 18, 2015 | CorelDRAW Graphics Suite X4 for PC...
Yes hello the problem is it dont read the empty sony dvd-r dvds so what can i do
Hello Ove,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not burn a DVD -R, chances are your DVD burner needs to be replaced. Good Luck.
  • If this helps resolve your issue, would you please rate the solution
Dec 27, 2010 | Sony DW-G120A DVD RW Dual Layer Burner
Hello sir, I have an ASUS DVD-RAM drive of model no. DRW-2014L1. It worked fine last 1 year but few days ago when I inserted a DVD disk I got a message "Windows cannot read this disk. This disk might be...
DVD Writers dont work as they grow old.
Sadly the Lense has stopped reading the Disk.
Try a few fresh DVD/CDs .
Still if u get the same message.
Dispose it off or get it repaired ( No guarantees that it will work)
Please rate and vote me to if you find the similar answers from the others as well
- WisBee
Sep 14, 2010 | Computers & Internet
Will not boot says operating system not found
if it was working before that message, then probably the operating system is corrupted.
insert the windows cd when you boot your pc and when the message "Press any key to boot from dvd" appear press enter.
Follow the screens to repair Windows. the sytem files will be restored.
Jan 25, 2010 | Toshiba Satellite A105 Notebook
Error :UiMsgID (121)
The encoded file has format ID 0, which is too old..If the job is corrupt, the problem occurred before or while the job was written to the queue.
Jan 04, 2010 | Microsoft Windows 98 for PC
DVD-Rom will read the movie but won't write (burn) it. Bad block of memry
>> The Device has a bad block of memory, which Windows attempted to read.
Which CD/DVD disk are you trying to _read_ ?
Can you read this disk in a different computer ?
If not, then the disk is scratched or greasy or otherwise damaged.
Does the error occur when you try to start to _write_ ?
If so, the "blank" CD/DVD media may not be compatible with your hardware.
Find a "writable" disk from a different manufacturer, and try to write to it.
If that works, then you may need to do a "firmware-upgrade" on your CD/DVD-writer, to make it compatible with newer "blank" media disks.
Apr 25, 2009 | Computers & Internet
I want to delete the annoying files...
hello, where do you find this files? maybe its a permission issue.
first go on the map ->tools->folder options and view
and unmark "user simple file sharing" ->ok
then rightclick on the file and "properties" ->security tab
check the permissions. click edit ->add everyone and set full rights. try then delete the file.
Mar 10, 2009 | Microsoft Windows XP Professional
Dvd/cdrw problems
it's windows problem,
follow this step from link (Microsoft) to edit windows registry
http://support.microsoft.com/kb/314060
if it isnot working, try to reload the operating system
Nov 30, 2008 | Acer Aspire 3690-2196 Notebook
Writer will read but not burn
Can you remove the burning software and try to burn by dragging files using the built in windows xp imapi? Check the event viewer for any system events around the time when you are having problems. Also try following these instructions: http://support.microsoft.com/default.aspx?scid=kb;en-us;314060 If you have another pc you can try the burner with, you would be able to rule out software issues.
Aug 26, 2007 | Optorite (dd0405) DVD±RW Burner
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
