Question about Canon Office Equipment & Supplies
I am trying to set up a canon mp700 to print wirelessly at home. We have dsl through Quest, which is connected through a 2Wire router, so we have wireless internet. We have one mac desktop, 2 mac laptops, and 2 ibm laptops. I had them all working and printing wirelessly at one pointsome time ago. But then the canon mp700 broke down and we had to exchange it. About the same time we started T-Mobile at home service, which required adding an additional router device. Now I am not able to get the printer to work wirelessly (it does print when we connect using a usb cable). Any advice?
marked
  • 6487 Answers
SOURCE: CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Posted on Sep 06, 2008
vswright
  • 84 Answers
SOURCE: HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Posted on Nov 22, 2008
patemi
  • 366 Answers
SOURCE: Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type 192.168.1.254 in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Posted on Jan 26, 2009
SOURCE: 2WIRE wireless router/DSL from AT&T
I can fix it. You need a print server for your printer with usb or parallel cable port on one end and ethernet port on the other end. Connect the print server to router and printer, install necessary software driver it comes with and you would be all set. I have connected 1 usb and 1 parallel printer with router.
I hope it helps. My m/cs are identical to what you have as far as OS goes
Posted on Mar 17, 2009
How do i setup my 2 wire router with dsl modem to network iat home
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
Need to find my wep key for my AT&T 2 wire 2700HG-B DSL router
The Default Wep Key is the 10 digit key located on the bottom sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simly accessing the router. I've listed the steps on how to access the router incase the Network Key on the sticker is not working.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya
Jan 31, 2011 | 2wire (2701HG-B) Wireless Router
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Problem with 2wire adaptor connecting to Avenue Broadband
Yes, The DSL connection and Broadband connection are different with each other.
You'll needing to reconfigure the router as Dynamic and clone the MAC address so that it will recognize to the network.
- Try resetting the router and reconfigure the settings of your router.
Mar 05, 2009 | 2wire HomePortal 100 Network Adapter
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Hello dstoller,
You have a Laptop
You have a Desktop
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Sep 06, 2008 | 2wire (1000-400108-001) Router
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
37 people viewed this question
old marine
old marine
