Question about Sun E2900 Server (E294P16GB1200)
TL = 1, TT = 10. ERROR: Illegal Instruction
System keeps on booting to OBP. cant get to solaris console.
  • teisatl Nov 27, 2008
    I've the same problem on a SUN 4900,
    the c0t0d0 disk cannot be encapsulated by Veritas, and I have the following error:
    Rebooting with command: boot vx-rootmirr
    Boot path: /ssm@0,0/pci@18,700000/pci@1/scsi@2/disk@0,0:a Boot args:
    TSTATE= 0x1400 [ccr = 0x0, asi = 0x0, pstate = 0x14, cwp = 0x0]
    TPC= 0000000000004000
    TNPC= 0000000000004004
    TICK= 80000048408a316d, TICKCMP = 8000000000000000
    debugger entered.
    Any ideas?
    Thanjs
    Sabrina
  • Anonymous Feb 17, 2009
    **************After install from base DVD (Solaris 9/05), system failed to boot with message: -
    TICK= 8000004be5bbfe34, TICKCMP = 8000000000000000
  • 71 Answers
Adobe acrobat distriller 3.0
SYSTEM REQUIREMENTS
Perl 4 or later installed on any of the following systems:
IBM AIX 4.2 or 4.3 with IBM?s Y2K patch installed
HP UNIX 10.x or 11.x with HP?s Y2K patch installed
Sun 5.4/Solaris 2.4 with Sun?s Y2K patch installed
Sun 5.5/Solaris 2.5 with Sun?s Y2K patch installed
Sun 5.6/Solaris 2.6 with Sun?s Y2K patch installed
Sun 5.7/Solaris 2.7
18 MB of hard disk space for Acrobat Distiller
32 MB RAM
INSTALLATION INSTRUCTIONS
The Acrobat Distiller 3.02 for UNIX Y2K Patch consists of two files:
-the distill file, which is the Distiller startup script.
-the distill.y2kfix.pl file, which is a Perl script that is invoked by the Distiller startup script.
To install the Acrobat Distiller 3.0.2 Y2K Update:
1.Make a backup copy of the distill file, which is located in the Distiller 3.02 installation directory. For example: cp distill distill.bak
2.Copy the distill file and the distill.y2kfix.pl file included in the archive to the Distiller 3.02 installation directory.
3.Make sure that the distill.y2kfix.pl file has execute permissions. For example:
chmod a+x distill.y2kfix.pl
4.Modify line 1 of the distill.y2kfix.pl file so that it contains the pathname to the Perl interpreter installed on your system.
5.Modify line 16 of the distill file so that the "install_dir" contains the pathname to the Acrobat Distiller 3.02 installation directory.
Oct 29, 2014 | Adobe PageMaker 7.0 for PC
Error 71 it keeps freezing
from : http://forums.xbox-scene.com/index.php?showtopic=484726
E71:
Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
  1. Go to the "system" blade
  2. Select "memory"
  3. Press Y on the HD symbol
  4. Press X,X, Left Bumper, Right Bumper, X,X
  5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
  6. Select Yes
Clear Any Failed system updates that cause the console to error.
  1. With the console off, press and hold the sync up button (the small white one)
  2. While holding the sync button press the power button to turn on the console
  3. Continue to hold the sync button until the Console has booted up completely.
  4. During the boot process the console should clear any failed updates, allowing you to use it normally
Jan 05, 2012 | Video Game Consoles & Games
Upon boot, it appears that the scsi is disabled???i have just installed solaris 10 on the machine.
solaris always give this problem.
don't wory
try installing it again
it might work?
Mar 17, 2010 | Sun Fire V240 Server
How do I install sun solaris from a grub prompt when I boot off the setup cd
A grub prompt is most likely coming off the hard disk where you're attempting to boot.
Restart the machine and adjust the bios settings so that the PC will attempt to boot from the CD or DVD drive before attempting to use the hard disk.
It's possible that you may need to burn a new image of the sun solaris ISO. That may be where you need to get help, if your system doesn't seem to be able to boot from this CD but CAN boot from others.
Jan 23, 2010 | Sun Solaris 10 3/05 (SOLZ910AC9A7M)
Dual boot Windows and Solaris
Hi there.
The only way to dual boot XP and Solaris is to reinstall XP, but seeing as you don't want to uninstall XP the only other option would be to install a virtual machine on XP.
VMware Player is a great app to install Solaris as a virtual operating system, this gives you opertunity to use both operating systems at once!!!
Get VMware player here >>>>>>
http://www.vmware.com/products/player/
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 20, 2009 | Microsoft Windows XP Professional
How to program the keyless entry for my 1996 Acura TL.
Hi, Stacie,
here's the instructions for a 97 TL - I hope they're the same.
Note:
Entering the programming mode cancels all learned keyless remotes, so
none of the previously programmed remotes will work. You must reprogram
all of the keyless remotes once you are in the programming mode.
You must complete each step within 4 seconds of the previous step to keep
the system from exiting the programming mode. You must program remotes
within 10 seconds of each other
1. Turn ignition switch to ON (II)
2. Within 4 seconds press the LOCK or UNOCK button on one of the remotes.
(An unprogrammed remote can be used for this step.)
3. Within 4 seconds turn ignition switch to LOCK (0) position
4. Within 4 seconds turn the ignition switch to ON (II)
5. Repeat steps 2, 3 and 4 two more times using the same keyless remote
used in step 2
6. Within 4 seconds press the LOCK or UNLOCK button on the same remote.
Make sure the power door locks cycle to confirm you are in programming
mode.
7. Within 10 seconds press the LOCK or UNLOCK button on same remote.
8. Within 10 seconds press the LOCK or UNLOCK button on all other
remotes you want to program. Make sure door locks cycle after you push
each remote button to confirm system has accepted the remote.
9. Turn the igniton switch to LOCK (0) to exit programming mode.
10. Test remote(s)
Hope this helps :)
John
Mar 26, 2009 | 1998 Acura TL
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Sep 10, 2008 | Computers & Internet
CDE in solaris
Can you try startx and clones on the command prompt ? can you send me the boot logs if possible if nothing helps ?
Jun 06, 2008 | Computers & Internet
Problem
Registry problems sir:
download this ose and repair ur registry
http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
and try to install in another location ( not in program files )
Nov 04, 2007 | Computers & Internet
Disc system failure error
U SHOULD SET HARDDISK AS U R 1 ST BOOT DEVICE.. I THINK THIS MAY SOLVE U R FROBLEM..
IF IT DONT HELP ,U. THEN..U CAN RE INSTALL WINDOWS..
best regards & best of luck..
Oct 12, 2007 | Intel Dot Station (INTC300AIO) PC Desktop
Sun E2900 Server (E294P16GB1200) Logo
1,447 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
