Question about HP OfficeJet 4215 All-In-One InkJet Printer
Paper will not feed into officejet 4215 to fax or copy, it stalls in the feeder.
The paper skids and will not feed when i try to fax or copy. does something need to be cleaned or replaced?
  • arleneheckma Oct 16, 2008
    THANK YOU
    I AM PRINTING OUT THE INFO FOR FUTURE REFERENCE. I APPRECIATE YOUR YOUR HELP.
    ARLENE
    Novelist:
    Scholar:
  • 111 Answers
Sometimes the feed rollers can get dusty or acquire other deposits on them that can cause a loss of friction, resulting in feed problems. You could try cleaning them to see if it would help. Here's the instructions:
Cleaning the Rollers
Post back your results and good luck.
Posted on Oct 15, 2008
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
Feeder tray does not feed during fax
Hp help
Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
Apr 28, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I have HP all in one. The feed for fax stopped working. how do I fix it.?
try copying blank pages. If it feeds the paper, then try faxing again. If it does not feed the paper, then open the feeder and clean the rollers and the separator pad. You can use a coffee filter moisten with distilled or bottled water to clean them.
Try copying blank pages again to check if it feeds the paper.
Feb 18, 2009 | HP Office Equipment & Supplies
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Document feeder is jammed and doesn't copy or fax
Is it jammeded or is it simply a warning saying it is?
Remove all paper and attempt a paper feed without paper.
The paper feed and delivery trays are removable so remove them and carefully reset them.
Making sure the paper is well fanned reload and retry.
Come back with the result.
Dec 13, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder
Its most likely to be the pickup roller and separation pad which will need replacing. as a short term fix try cleaning them with some isopropyl alcohol
Sep 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Problem with feeder on HP Officejet 4215
Hi Dwterrell,
Please click on the web link given below and perform the steps given in the web page.
I will provide you two web link which will fix the issue for you.
Link 1
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00097153&cc=us&lc=en&dlc=en&product=351106
Link 2
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=351106
This should fix the issue.
Apr 26, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
277 people viewed this question
Ben Johnson
