I am using Paperport Version 8 on Windows XP/Visioneer4400 scanner When i scan a document using scan manager the document is stored in a folder under a different date, not the current date. I have recently reinstalled the programme, before that everything was OK. Thanks in advance Steve
I went into Options and selected the Item tab.
I selected Custom kept the box clear and pressed Ok.
I then scanned a document and the date shown was correct.
I went into Options again and selected Predefined. And the programme runs correctly.
Posted on Oct 11, 2008
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other...
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
Mar 07, 2014 | Visioneer Office Equipment & Supplies
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
I use PaperPort 8. When I try to print to PaperPort or PaperPort Color, everything appears to work fine but the item doesn't get to the PaperPort folder. this happened once before and someone at FixYa...
http://www.fixya.com/support/t763517-paperport_selection_printer_but_item
http://nuance.custhelp.com/app/answers/detail/a_id/5852/~/changing-the-default-folder-location-for-paperport
https://support.brother.ca/app/answers/detail/a_id/86451/~/how-do-i-change-the-folder-to-save-scanned-documents-in-paperport-12se%3F
http://paperport.helpmax.net/en/changing-paperport-options/changing-paperport-options/changing-the-default-folder-name-and-color/
May 01, 2017 | Computers & Internet
Describe your scansoft paperport deluxe 9 windows Vista printer drivers Problem Can not install why
Hi there and welcome here
Take a look here :
http://reviews.cnet.com/document-management/scansoft-paperport-deluxe-v/1707-3522_7-30787056.html
It does not describe windows Vista, so I think it is not compatible with windows Vista, so there is 2 thing you can do :
1. you can see if it runs in compatibility mode, and you do it in this way : Highlight the program icon on the desktop or in the start folder, choose properties, select the last tab, choose compatibility mode with windows xp and try to open the program
2. If it is not working maybe you can upgrade to a newer version, for that you have to go to the product homepage . Normally you find a link in the program where you can go to the product homepage.
Hope this can help
Have a nice Christmas over there
Please rate my answer
Dec 22, 2009 | ScanSoft PaperPort Deluxe 9...
Brother MF-8440 scanner driver and document manager for Mac OS X
Open preview and go to file and then scroll down to "import from scanner" MFC should show up as a choice and then when the window appears, go ahead and pick your preferences and scan
Mar 01, 2009 | Brother MFC 8440 All-In-One Laser Printer
HP5550c scanner using Paperport 7.0LE - slow scanning
Have you noticed any quality difference in the scans? Sounds like it is set to scan at a higher resolution which will take longer.
Dec 18, 2008 | DPI TravelScan-PaperPort 7.0 LE 230UP ((((...
Scanning problem with a CanoScan8600F
Hi
 go to the your scanner properties please see there your current path.. and change the the path.. select your free hardisk space..which driver you've free space.. ther only stored you're all documents...
it will work
Nov 18, 2008 | Office Equipment & Supplies
Scanning multiple page documents
Yes you can. You need a small scan application whitch allows you to scan multipages.
There are for example ScandAll21 from Fujitsu (freeware) or PaperPort 11.
http://www.opendrivers.com/driver/229211/fujitsu-scanners-scandall-21-v4.2.34-windows-free-download.html
http://www.nuance.com/paperport/
Jul 18, 2008 | Epson Perfection 1250 Flatbed Scanner
50 people viewed this question
jasbo
jasbo
