Philips VL1200 Video Sender IR Blaster broken
I am trying to find an Infra Red Blaster for my video sender. The senders are working fine. Only my 2 year old decided to break the little black connector. Am not well up on the internet to be able to source one of these cables. And don't know the exact keywords to use for locating one of these cables.
I managed to get it soldered. Thanks anyway.
Posted on Oct 14, 2008
Hi, I m driving Daewoo lanos 2000 m0del hatchback, my petrol gauge decided to stop working 2 days ago, what is the problem?
could be anything but if you are mechanically minded and can get to the sender(sometimes an opening/cover) under the back seats and you will find a plug on top of the fuel pump/sender assembly that goes onto the top of the fuel tank - if there are 4 wires - 2 large and 2 small the 2 small are for the sender. unplug it and link the 2 small wires and if its the sender broken your gauge on the dashboard should read full with the ignition on.
Sep 18, 2017 | Daewoo Cars & Trucks
2004 sunfire; temperature gauge wont move. I checked the temp sensor and harness and they are both working fine. What else could it be?
the temperature sensor and the gauge sender are two different units
the wire to the temp sender could be broken or fallen of the sender
that wire has power to it and needs to be connected to the sender so that the variable resistance in the sender can work the gauge
Mar 25, 2017 | Cars & Trucks
Fuel sending unit test and replace
Checking and replacing a fuel sender unit ' How a Car Works
www.howacarworks.com/fuel.../checking-and-replacing-a-fuel-sender-u...
Learn how to check and replace a fuel gauge sender unit, and how to check a fueltank. ... Fuel pipe Sender lead Breather pipe Sender unit Petrol tank Filter Float arm Float Mounting flange Filler .... Test by quickly removing the filler cap.
How to test a Fuel Sender - YouTube
? 2:01
https://www.youtube.com/watch?v=hHzeOOzQKR8
Dec 1, 2012 - Uploaded by TheyMightBeRacing
This video shows the basics of how to test a fuel sender to ensure that it is ... Trailblazer fuel gauge not working/sending unit test and replace ...
Trailblazer fuel gauge not working/sending unit test and ...
? 17:29
https://www.youtube.com/watch?v=aIMDauRGwFg
Sep 23, 2012 - Uploaded by MAY03LT
How to replace the fuel sending unit in the 02-03 Trailblazers. I also show how the fuel gauge works and how ...
Toyota Corolla Fuel Pump Removal Sending Unit Testing ...
? 6:17
https://www.youtube.com/watch?v=JtYMRrUpZr0
Oct 29, 2014 - Uploaded by richpin06a
Toyota Corolla Fuel Pump Removal Sending Unit Testing. ...Camry 1997 1998 1999 2000 2001 fuel pump replacement - Duration: 9:32.
Jan 13, 2016 | Cars & Trucks
No picture on computer from sender
Seems like either their webcam isn't working properly, or their Internet bandwidth is too low to support the video stream.
Sep 02, 2014 | Apple Computers & Internet
Cant get video sender remote control to work consistantly. sometimes 2 red lights appear on receiver remote control window and this is when the remote wont work. when only 1 light appears it works ok
Check the voltage from the power supply incorrect voltage will not power your device correctly therefore it seems not to b getting enough power so that's why only one light lights up or the unit itself has a circuit board short and needs replacement ..
Feb 24, 2014 | OEM Systems 5.8GHz Wireless Audio Video...
My temp gauge quit working and i replaced sender and gauge. it's got to be a short. but where to start maybe someone else has had the same problem
95 yj (quite means, hot , low or mid?,) just a clue.?
4.0L? all fuses good,?
the FSM covers this , here is the outline (all cars this era)
1: IR pyro gun pointed to thermotat housing near 180f 170f min.
2: ok engine really IS hot. then we ground the gauge feed, meter,
pegs, meter good , I use a light bulb from ground to guage to
limit current (im nice to my meters)
3: i then find my temp sender, the one with 1 pin.
pull the connector with a hot engine
this is a passive NTC thermistor and is not the ECT with 2 pins.
its just for the gauge.
the 91 sender is different from a 95 so dont mix years,!!
92-95 are matched.
hot engine, 180F or more...
pull off the single wire. to the sender.
connect DMM set to OHMS (yes, omega symbol i s that)
select 200 or 2000 range, id use 2000, , if an auto ranging meter
let it range and read the LCD markers, it tells you what range it landed red to pin, the black to engine block. (rear top sender on 4.0L)
its not the sender bad, all in 5min work. no guessing at all
so if its good, the wires are bad. twinxed them.
the only hard part is finding good ohms charts that match your year.
all else is caveman simple 1 wire, gauge and sender.
i see many folks online mixing wrong clusters in jeeps
and wondering why the right sender dont work.
so did you cluster temp ever work right, this year, this decade?
ohms law , never lies, but wrong parts do.... every time.
the sender is NTC, higher ohms cold, , lower hot !
i could not FIND the sender spec. at all.
1million hits for ETC, zero for gauge.
my guess is sender will read high ohms cold , 1000 or more. more cold more ohms... (resistance)
then drop in ohms as engine warms might drop to as low a 80 ohms.
but will drop , gauge wire (it only has 1) disconnected.
Dec 31, 2013 | 1995 Jeep Wrangler
Repair broken gas gauge
Most gauges work ok but the sender unit in the tank is what causes most problems. I would be looking for a broken/loose wire to the sender or a faulty sender unit
Sep 28, 2013 | Honda Accord Cars & Trucks
Connect hq +5.8ghz video sedder to a tv
I believe you have this backwards. In the usual setup of this type, the sender is installed in a remote location and controlled by the TV remote. The 5.8 gHz sender output is sent to the receiver which is positioned in front of the Infra red window on the front of the TV. The received 5.8 mHz signals are converted to infra red output to control the TV
Feb 08, 2013 | YouTube Videos
Tv not responding to remote
the remote may have dropped and there are 2 possibilities of fault.
1-acrystal which gives accurate frequecy was broken
2- the infrared sender led was burned or the printed cicuit connection for this IR led is broken
Jan 28, 2013 | Sonic Impact Technologies Sonic Impact...
My remote
Let's start with the obvious. batteries good? base plugged in and have power? sender and receiver have direct line of sight? I know this sounds simple, but if any of these is not working, the whole chain will not work so make sure!
Sep 01, 2007 | X-10 RemoteSender IR-Blaster Cable Remote...
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
