Question about Cameras
Hi my son dropped my digital camera while the lens was extended and now it wont retract and it says zoom error also the shutter wont open fully or close, the lens is at a slight angle and wont budge do i have to take it to get repaired or can i pull it apart myself thanks
  • appreciative Jan 12, 2009
    This worked for my camera. I had to try it several times, before the lens went all the way back into position. I just kept turning it on and off and pushing it down against a mat on the table. The first few times, it still said to turn it off and on again without the lens closing all the way. The great news is that this solution saved my brand new camera after my daughter dropped it.
    I'm very grateful
  • 489 Answers
Hi
It helps to know the make and model of the camera, some cameras the lens is too fragile and we have never been able to repair them. Other models we have had a great deal of success repairing them. (Google: darntoothysam)
One trick you can try... at your own RISK... is to put the camera lens on the edge of a table and gently but firmly push it back towards the middle and try to get it to CLICK back into place. There are three small metal pins inside the lens barrel and these pins ride in grooves in the inside of the lens, this makes the lens move in and out... If your lens is at an angle, at least one pin has jumped out of its groove.
Put the SIDE of the lens (NOT the flat front of the lens, the rounded side) on the edge of the table with the camera body not touching anything. Push the lens back towards being straight again and it will either click back into place or it wont. Even if it does it may not work, or you may damage the lens further.
If you don't want to try this or if you find you need the lens replaced, we can help, we are an affordable digital camera repair business, feel free to check us out and let us know if we can help.
Good luck from Darntoothysam com
Thomas
Posted on Oct 10, 2008
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
The camera was dropped on the lens and zoom won't retract
HI there, the camera lens gear is damaged from internal. So you must changed that. Other wise it gives you lot of trouble. Thanks.
Mar 12, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens error, restart camera
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens will not retract
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon Powershot 560 Error message lens wont extend
hi there
you have faulty spring and you need to have that serviced at a service center. check if you need to replace the spring or just correctly put it back into position. hope this helps.
fixya!
Jan 30, 2008 | Canon PowerShot A560 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Photosmart m627 camera
It sound like a problem with the zooming mechanism, does your camera was dropped down ? In case it dosen't, since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem. Good luck!
Aug 13, 2007 | HP PhotoSmart M627 Digital Camera
Cameras Logo
422 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
