Question about Dell 924 All-in-One InkJet Printer
Dell phto 924 clear the carrier jam
My printer has been saying this for months now and i cant find anything wrong with the carrier jam.. there is nothing in there. what do i do???
    Sniper:
  • 69 Answers
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
I HAVE THE DELL 924, which KEEPS SAYING CLEAR CARRIER JAM AND MAKING a loud banging sound, BUT there is NoTHING BLOCKING IT. WhAT CAN I DO to fix the problem?
THE HOME POSITION SENSOR OR CARRAIGE ENCODER MOTOR IS BAD. IF UNDER WARRANTY, CONTACT DELL FOR REPAIR/REPLACEMENT. IF NO, A NEW ONE AT SUPERWAREHOUSE.COM IS MORE ECONOMICAL THAN A REPAIR. THANKS
Jan 08, 2011 | Dell 924 All-in-One InkJet Printer
What is a Carrier Jam?
You might have lost a little spring. Can you possibly return it to the store where you got it?
May 16, 2009 | Dell 924 All-in-One InkJet Printer
Carrier jam on 926 dell printer
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for code 1200 in the middle of the page. good luck!
Feb 13, 2009 | Dell 924 All-in-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jam
hi,
Follow the wizard on the following website , to help you to pinpoint the problem
http://tinyurl.com/3nh59x
Thanks
Proton
Oct 02, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Carrier jam
Try and manually move the carrier. If it is stuck, dont forcefully move the carrier.
Jul 13, 2008 | Dell 922 All-In-One InkJet Printer
Need to fix a carrier jam
you have to open the printer and check for any parts is struck or dislodge
Jun 23, 2008 | Dell 924 All-in-One InkJet Printer
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
218 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
