Question about Magic Chef CYE4000AWW Electric Dryer
Dryer is broken
I have a kenmore dryer mod 110.64722400 it stopped working . There is power going to it the timer works and the light comes on when you open door. there is no heat and the drum is not moving what should I do first ?
  • 706 Answers
Hello co5nixons,
Will offer a few things for you to try.. First off.. are you sure you haven't lost one power leg of your incombing power feed? You may want to get a friend that is an electrician or someone that can check your input power at both the receptacle and the terminal block inside the dryer. If youi are missing one phase of power, you may get the electronic control system to look like it is operational but your motor or heater element will not work.. That is where I would start..
Please get back to me if you or someone you know checks that and it is OK.. I'll try to help you resolve this...
Regards
Posted on Oct 11, 2008
Kenmore dryer stopped working, still has power.
When the timer stops during the duration of the time set the timers cogged tooth gearing has stripped out. A new timer will be needed to get your dryer working again
Apr 07, 2010 | Dryers
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Sep 04, 2009 | Dryers
Kenmore Dryer Wont Start
The belt was broken and once replaced it worked.
Jul 06, 2009 | Kenmore Dryers
Kenmore 70 series stopped in middle of drying and won't work now
If your dryer is not getting power there are some things that can cause this problem,
No house power supply going to the dryer,it could be a tripped breaker or blown fuse depending on which kind of electrical panel you have.
A bad or defective door switch, if the door switch does'nt work the dryer will not run.
The power cord connected to the dryer could have a Broken or burned connection at the dryers teriminal block.
If the thermal fuse is blown the dryer will not dry or it may not work at all.
If the timer is bad you might have to call a appliance repair man.
Mar 26, 2009 | Kenmore Dryers
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
Magic Chef CYE4000AWW Electric Dryer Logo
51 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
