Vertical hold problem on mitsubishi rear projection vs50,cant find V HOLD adj on circuit board
  • 8,617 Answers
Faukty PIP module will cause the TV to roll on that model as vertical sync runs through the PIP module.
Posted on Oct 11, 2008
Vertical hold problem on mitsubishi rear projection VS 50605 can't find reset button. Where can I find it.
Your Vertcal Hold Problem Is Due To Lack O f( Sync) Hold Which Is Usually Caused By Defective Filtering In The Vertical Output Circuit
Sep 10, 2014 | Mitsubishi WD Televison & Video
I have a 1999 Mitsubishi Projection TV and the vertical hold wont adjust. How do I reset it.
Put it back to the mid point of it's adjustment range.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced.
Sep 10, 2014 | Mitsubishi Televison & Video
Vertical hold problem on 1999 Mitsubishi rear projection VS 50605 can't find reset button.
I have a Mitsubishi VS 50605 projection tv that needs to have the vertical hold reset. How do I reset it.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced..
Mitsubishi ws-55313 vertical hold problem with tv
This set does not have a vertical hold control etc---try to explain what the set is doing or not doing so I or another expert can help you.
SD TECH
May 18, 2011 | Mitsubishi WS-55313 55" Rear Projection...
I have lines like vertical hold is off but can't find ajustment
Thank you to "TheScreenGuy". He replied with an answer that says the vertical sync is automatic and that I need to replace the SSB. Thanks!!!
Mar 23, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS 50707 ( not 705)
I have the same TV built in 99. My problem is similar but the vertical hold gives out when the tv warms up about 5 minutes. I will attempt to locate the vertical hold circuit and replace any parts I suspects may be the problem. I suspect a cap is leaking or transitor around IC700 is degrading when warm.
Jul 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
TV shutdown for roughly 10 - 15 minutes after being on for hours
Yes the vertical circuit will shutdown the set if theres a problem with the deflection circuit. This model has a history of leaking CRT coolant on the boards near the vertical IC destroying the solder and actually eating through the circuit board. Check the area near the Vertical output IC for signs of coolant leakage or solder cracks.
Mar 11, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Vertical hold not working
on mitsubishi just replace the caps that are near the vertical ic this will fix the problem good luck
Nov 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi ws-55813 horizontal hold
When you say horizontally, do you mean it collapse or it scrambles. Because the 2 are different problems. If you pictures shrinks or collapse then it is in the vertical circuit. and if it scrambles itself almost like you can see the picture but it is broken up over and over again, then this is video problems in video circuit. Need more info
Aug 13, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Electro Med Services...
