Computer Screen I just got this computer screen from my mom. I have a DEll modum and a NEC AccuSync 700 Screen. I for some reason can't seem to get the colors the way they should be for some reason were it should be white it's pink. How can I fix this problem? By the way I am very Comupter Illiterate. PLEASE HELP!!!
    Genius:
  • 1,124 Answers
Check the screen settings resolution in your computer
Start >> Control Panel >> Display
Reset your monitor to factory settings.
Posted on Oct 10, 2008
  • Pablo Csaky
    Pablo Csaky Oct 17, 2008
    Thank you for using FIXYA!
    Dont forget to rate my help!
    Have a great day!
    Pablo :-)
    Let me know if you have further questions about this issue.
    Genius:
  • 1,605 Answers
Go the nec.com dowload the accusync 700 driver. and install it. you should be able to adjust the color.
http://www.necdisplay.com/SupportCenter/Product/?product=c8d9bbed-1efb-42fa-851f-a56963c425fe
Auto adjusting
This is normally caused when the monitor does not support the screen resolution the computer is set to. Change the screen resolution and see if that helps. Also, consider updating your graphics driver too.
Hope this helps
Steve
EmoticonIT com Computer Solutions Lincolnshire Joomla Websites IT...
Apr 30, 2014 | NEC AccuSync® LCD73V 17 inch Monitor
Touch screen
Does the touch screen work?
Oct 15, 2013 | NEC AccuSync LCD72VX LCD Monitor
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
What flatscreen monitor is OK to substitute for sanpo alphascan 520?
Hi. Almost all the crt type monitors should work, it's flat screen monitors that seem to give computers problems with aspect ratios, and resolution settings.
I personally use an NEC AccuSync 70.
It might not be the newest monitor in the world, but the colors are crisp, clear, and bright.
And It allows a setting of 1024x768@85 hz refresh rate, which works great for my games.
As far as flat screens, I would probably go with an Acer, or a Dell monitor, as these two companies seem to have better quality from their monitors than most other manufacturers.
I hope this helps you out!
Mar 06, 2011 | Sampo AlphaScan 520 (White) 15 in.CRT...
Large screen
try clciking auto on screen or downlaod grathics drivers eg intel grathics , then u can change from there
Apr 27, 2010 | NEC AccuSync 900 19" CRT Monitor
Getting black horizontal lines across the screen. It started off as an intermittent problem, now occurring more often. I changed the video card and the power supply tests fine and I changed the refresh...
I would test the cable, use it on a different monitor or try a different cable. That is the only other thing to check, otherwise it definitely is the monitor.
Apr 07, 2010 | NEC AccuSync 700 (White) 17 in.CRT...
How do I fix my screen from being blurry? I have an AccuSync LCD 72vw with AT&T services.
Hello: Try the following:
Signal cable should be completely attached to the computer.
Use the OSM Image Adjust controls to focus and adjust display by increasing or
decreasing the FINE control. When the display mode is changed, the OSM Image
Adjust settings may need to be readjusted.
Check the monitor and your display card with respect to compatibility
and recommended signal timings.
If your text is garbled, change the video mode to non-interlace and use 60Hz refresh rate.
Nov 19, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
NEC flat screen monitor reset screen keeps popping up.
Call 800 836 0655 and ask for directions from tech support.
Nov 14, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
Computers & Internet Logo
David Payne
David Payne
