Replace start button on Bosch Washing machine WFK 2401
Start button spring holder broke - have to manually hold button in for entire cycle. How do I access to replace start button? Any special info I need to do this?
  • jw88888 Mar 09, 2009
    I have a BOSCH WFK 2401 washer. The press-botton "start" is not working now. I have to keep pressing it in order to keep the mechine working. If I don't, the machine will stop working immediately. Can I get someone to fix it? How much it costs? A friend tole me that the part is out of work, and it would spend about $300.00 dollars to buy a new one. If it is that expensive, probably I have to buy a new one. But that one has to match my dryer. My dryer is BOSTON WTA 3500 and WTL5400. Where I can find a washer that matches with my dryer if I can't get it fixed. Thank you very much!
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Posted on Jan 03, 2009
philbran
  • 242 Answers
SOURCE: Bosch WFK 2401 hot water wont shut off even if you turn power off
I can help , If the unit is leeting water in with the power off the only thing it can be is the water inlet valve , it is the componet you connect your water line to under the unit behind the front lower panel. Tell me if you have any other questions and let me know how this works out.
Phil
Posted on Jan 07, 2009
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
beltronic205
  • 1456 Answers
SOURCE: Bosch WFK 2401On/Off Switch
You need a new switch should be able to buy on its own note wiring before doing.. it just pops out i think..good luck
Posted on Sep 29, 2009
  • 1416 Answers
SOURCE: I have Bosch WFK 2401 UC Washer and it will not
hello,
this simply mean that some of your material have gone to block the water flow out unit what you have to do is to bale out the water then remove the cloth that have block the pipe .
thank you and good luck.
Posted on Jun 03, 2010
Bosch wfk2401. machine stops and lights start blinking " error code 03"
washing machine does not spin on any cycle , however the belt is fine. Any recomdenations
Jun 13, 2011 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
Sep 08, 2009 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Remove motor plug
Thanks.
Jan 12, 2009 | Bosch WFK 2401
WFK 2401 DOOR does not open anymore
where is this machine i might be able to help over the phone
262-893-4840
Apr 23, 2008 | Bosch WFK 2401
Fault Code 06
put the selector switch on the x setting and hit the start button it will tak 60 sec and the door will unlock
Apr 19, 2008 | Bosch WFK 2401
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
