Question about Panasonic TH-37PX25U/P 37 in. HDTV Plasma
PANASONIC TH-42PX25 NO PICTURE ON ANY SOURCE. OSD FINE
TH-42PX25 NO PICTURE BLACK SCREEN ON ALL VIDEO SOURCES. OSD WORKS FINE AND CLEAR. NO NOISE ALL FANS WORKING GOOD. SS BOARD SHOWS 2 LED LIT. SERVICE MODE ALL CHECKED OK. I SUSPECT "D" BOARD?
JEFF
  • Anonymous Feb 21, 2009
    I am having the same issues, was it the d board?
    thanks
SOURCE: WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Posted on Mar 26, 2008
SOURCE: TV source button will not stay lit during set up
I'm having the identical problem.
Posted on Jun 02, 2008
VOTIT
  • 2071 Answers
SOURCE: panasonic plasma th-42px25 turns itself
The condition of your TV called power supply overcurrent shutdown. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating .I would probably also check the flyback circuit and flyback transformer although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
Posted on Sep 03, 2008
  • 51 Answers
SOURCE: th-42px25 red picture, no blue or green
If using component cables check connections at TV or from source. If all rae ok the try source on another tv before getting video input circuit board replaced on tv
Posted on Dec 15, 2009
  • 6 Answers
SOURCE: All the leds are lit up. The amp works with
sounds like there is a short in a wire.either to the speakers or to the preamp check all cords for breaks
Posted on Sep 03, 2010
I have a Panasonic TH-42PX25 that was running fine. Turned it off the other night, next day I powered on but no picture. It seems like there is a very faint glow to the screen, but no picture. Just a
Sounds like main power supply regulator board is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 24, 2014 | Panasonic Televison & Video
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
My picture scatters every minute or so and then comes right back....
The good: Deep blacks; decent video processing; accurate color that doesn't overaccentuate red; generous connectivity with two HDMI inputs; aspect-ratio control with HD sources.
The bad: Depth of black fluctuates depending on how much bright content is in a given scene; no PC input or picture-in-picture.
The bottom line: The Panasonic TH-42PX60U sets the standard for value among full-featured 42-inch plasmas.
Shunpian Dai links:http://www.chinaicmart.com http://www.seekic.com
Jan 05, 2011 | Panasonic TH-42PX60U Television
Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Apr 14, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sound, No picture
Try another video source. Try a digital source and an analog source. If you still get nothing, think about replacing the DG board and the H board.
Dec 19, 2009 | Panasonic TH-42PZ77U TV
Th-42px25 red picture, no blue or green
Dec 14, 2009 | Panasonic TH-42PX25U/P 42 in. Plasma HDTV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH-37PX25U/P 37 in. HDTV Plasma Logo
300 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
