Question about Grilling
Yellow flame on our gas burners
We have 6 rambo high pressure gas burners in our temple and a lot of them are running a yellow flame which is giving a low heat and blackening the bottom of our pots,there are some air ajusters under them but nothing happens when i turn them, i have all so drilled the holes to check there not blocked, what should i do or check next.
Thankyou
Tapan krishna
    Scholar:
  • 82 Answers
Hello. Have you tried replacing the regulator? Sometimes spider webs can get into the burner valve orifices or inside the burner ports. You may even also need new burner valves. Let me know if you need to know where the regulator is.
Posted on Dec 03, 2008
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
Pilot flame flickers when burners on and drops out valve
You should either do a smoke test or use a candle to check for drafts to be sure that it is not a gas pressure issue.
Aug 13, 2014 | Kingsman FDV200 Free Standing Direct Vent...
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
I have an indesit cooker both gas and electric and when am using gas it produces poor quality fire which causes soot onto saucepans. please help
Soot is unburned carbon in the gas and is caused by the flame being short of oxygen. The burner assembly may be dirty or your air adjustment is off. Once a burner starts to make soot, it gets progressively worse on till it is repaired. The first thing to try is a good cleaning. If that does not solve it, look for the air adjusters. They should be near where the supply gas line meets the burner orifice. open them a little at a time and watch the flame for change. More air should clean up the cabon. Also check the gas pressure regulator for proper adjustment. It could be set too high. Let me know how your doing, OK? Roger
Apr 20, 2011 | Heating & Cooling
Furnace seems loud when burners ignite like a small "woof" didnt always do that seems to be something new. Checked all venting nothing obstructed. Had gas presure checked it is LP input is 10...
Depending on the age of the unit the gas pressures should be fine. The first thing I would do is to give the burners a thorough cleaning and make sure pilot is clean if so equipped. I would shut furnace off and remove the burners for easier and better cleaning. Use a wire brush to lightly clean openings on the burners,and gently tap inlet end of burners on soft wood block or thick cardboard pad to clean soot and rust from inside the burners. Also blow out with air if you can.
I always do one burner at a time and put them back in the order they were removed in. When you get everything back together and furnace lit then you can loosen retaing screws on air baffles if needed to get the best looking cleanest flame possible.Flames should be tight on the top of the burners with nice blue flame with sharparrow points with just a little yellow on the very tip.
I hope this helps you. Thank you
Jan 10, 2011 | Heating & Cooling
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Sep 02, 2010 | Pitco Frialator 35CS Deep Fryer
On an atwood water heater, I have a small yellow flame at the main burner orifice, but nothing comes through the burner tube. The tube is clean and so is the orifice. The gas valve is new.
You need to have a manometer (pressure test) done on your system. If all that is new and clean, as stated, then you either have low pressure or a faulty/improper, gas control.How's the flames look on stove burners?
Jun 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Oct 31, 2009 | Thermos 0210-1309 Turkey Fryer
Burners are bleeding gas causing rollout flames
multiple problems can be causing this: 1.burner orfice restricted 2. make up air 3. blower motor or relay defective 4.gas pressure to high 5. not enough gas pressure 6. restriction in gas line 7. defective gas valve 8. defective control or ignition module........recommend qualified tech. to look at
May 23, 2009 | Pitco Frialator 35C Deep Fryer
Grilling Logo
291 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
