Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer wont stop fillingup and does nothing when advanced to spin cycle you can hear timer running but does not advance
  • colbertjg Feb 22, 2009
    I had an issue similar to this. My washer just kept running and would never advance to the agitate cycle. So I would turn it on and the water would pour in and then right back out the drain pipe. I called customer service and they were very helpful! The problem was the drain pipe was lower than the level of the water so all the water was running out of the drain pipe. The fix was just to pull the drain pipe out of the drain tube and put something around the hose to keep it from going that far down again. Hope this helps.
    Jason
  • 943 Answers
Hi thanks for your question. how do you turn the water off with the taps. i think you have a water level problem .check the water level switch thanks the appliance doc
Posted on Oct 16, 2008
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
My Whirlpool Toploader washer model LSR8233JO1 stops at rinse cycle after draining. I have to manually advance it to the spin cycle and sometimes it won't spin.
Dawntm,
It is possible that you have a timer issue since you say you are having to manually advance the timer. There is a small motor mounted on the timer that normally advances the timer and for some reason, possibly a burned contact, it is not advancing from that point. You might need to call in a repair tech. Hope this helps!
Jun 30, 2015 | Whirlpool Washing Machines
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Top Load Washer cycle problem
check the lid switch by putting a screwdriver into the lid switch hole; look at your timer duration diagram it's in the control panel a small sheet of paper taped inside Does you machine not advance mark the timer knob and, see how far the knob advances next set the timer for the agitate position and check the timer for continuity on those pins noted on the sheet
May 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool Washer wont spin or drain
    check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
    Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    73 people viewed this question
    Dan Webster
    Dan Webster
    Mike Cairns
    Mike Cairns
    prem mathew
