Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Memory cards does not work
My me,mory cards does not work and tell me cards error on ixus cannon digital
  • Canon Master
  • 4,738 Answers
First remove battery and card and look in your flash card slot for any bent pins. If you see some, don't fret. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
If there are no bent pins, then the internal BIOS battery has likely run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Also, see the following link for tips on contacting Canon regarding camera advisories. This particular post concerns a CCD advisory, but the tips are the same:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Posted on Nov 01, 2008
Why will a picture on my memory card not delete?
the memory card might be set to safe delete on . remove the memory card and switch it off then try to reformat the memory card
Aug 16, 2014 | Cannon Cameras
Cannon IXUS IIS memory card error
Hello....
last week, i too had faced the same problem and got this recovery software for mac file recovery from memory card. You can also download the demo version and check the recovery results.
Jun 16, 2012 | Canon PowerShot SD110 / IXUS IIs Digital...
MEMORY CARD OF cannon digital IXUS 80 I5 GOT LOCK.HOW TO UNLOCK IT.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 15, 2011 | Canon IXUS 80 IS Digital Camera
MY CANNON IXUS 210 DISPLAYS MEMORY CARD ERROR WHEN TAKING A PHOTO AND DOES NOT SAVE THE PICTURE
This problem is so common, especially with Canon Powershot cameras like your IXUS 210, that there's a whole blog about it here:
http://hubpages.com/hub/Canon_Powershot_Memory_Card_Error_Fix
It seems that the camera gives this error when it has problems reading/writing the card. The fixes they suggest there are to do with cleaning the contacts. It's pretty easy to clean the contacts on the memory card, but much harder to clean the camera. I don't suggest following the instruction to spray cleaner into the slot... that sounds like a recipe for getting it all over the inside of the camera!
I would start by cleaning the memory card's contacts. You can either use a solvent such as Methyl Hydrate and a Kleenex, or you can actually rub the contacts clean with an eraser (or if you're British you can use a solvent such as Methylated Spirit and a tissue, or rub the contacts clean with a rubber). It's probably worth looking inside the camera too, to see if any of the contacts are obviously bent in the card slot. I've seen that in a Nintendo DS which is similar. If a contact is bent, nothing's going to work unless you can get it back in place.
Mar 23, 2011 | Canon PowerShot SD3500 IS / IXUS 210...
I got a new 4gb memory card for my cannon ixy 800is camera but it says memory card error.the make of the card is apacer. Do you have any suggestions on how i can fix this. I have not tried to clean the...
A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 10, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
Hi there,I was wondering if a 4GB SDHC card was suitable for a Cannon IXUS 4.0 or not? I can't seem to format it?
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. It is often difficult to find out the maximum capacity card that a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
Dec 01, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
Memory card is locked for Cannon Power Shot SD790 - how can I fix the problem?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Sep 06, 2010 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Card locked
Dear codger19:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
May 31, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory card error
check to see if the little pin on the memory card is set to "lock", this prevents the camera from accessing any of the data on the card causing this problem
Jan 09, 2008 | Cameras
Memory card problem
hi
I was happily using Cannon IXUS 750on one of my long vacations when the memory card almost got full. perhaps I clicked once or twice to take a picture when the card was full. ever since the camera displays Memory Card Error.
These are almost all the photos I took on my camera since a long time now. Could anybody pleeeese help me in retrieving my photos and recordings?
thanks v much
Nahar
Oct 30, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
48 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
