Question about iRiver H10 MP3 Player
IRiver H10 Turns On but then Turns Off After 20-50 Minutes
My iRiver H10 is fully functional except for the fact that when I'm using it, the screen will flicker and then it turns off. Then I can't turn it on again until 5-10 min afterwards, but when I do turn it on, it says the battery is almost dead, however, when I turned it on the first time, I already had it fully charged. The only conclusion I can come to is that the battery is busted or something. Also, I have dropped my H10 a few times on accident so that could be the cause of the problem. Please help me.
  • 3 Answers
Yes by the sounds of it , it is your battery try buying a new battery and see how it works form there if it is still playing up you will have to go to your nearest electronic shop and get them to have a look at it
Posted on Oct 12, 2008
Need to reboot iriver h10 cant delete songs
Ok , sorry it took me until now to answer , this is a very simple procedure and I promise it will fix your Iriver! All you have to do is go to main menu , scroll down to settings . Then go to additional settings and at the very bottom select " Database Refresh " . This will fully reboot your irvier H10 , and will flush anything harming your mp3 device .
Hope this helped :)
- Chris
Feb 15, 2010 | iRiver H10 MP3 Player
When I push the power button, the screen only lights up for a second and then a lock symbol appears and then it turns off by itself
It might be the fact its on lock. so on top of the iriver there is a lock switch flick it the other way that might help. Sorry if it doesn't
Feb 07, 2010 | iRiver H10 MP3 Player
IRIVER WONT WORK AAAAHHH HELP!!!!!? my iriver wont work when i try to turn it on it comes up and says system files missing to restore the system files, connect to iriver plus wat dose that mean i have...
When system files are missing on the player, you will need to reinstall the FIRMWARE.
When looking online for the connection type for the H10 / H10JR, I can see 2 CONNECTION TYPES for the H10 / H10JR:
1. MTP, when using Windows Media Player 11 ( WMP11 ), for the H10.
2. iRiver Plus, when using iRiver PLUS, for the H10JR.
The connection type determines what software on the computer will be used for transferring media.
Each software on the computer needs corresponding firmware on the player to be installed.
When the player itself comes up with the information to connect to iRiver PLUS, this is the correct software for this device probably. Then the device is a H10JR.
When not having the program iRiver PLUS, go to the iRiver support site, for the download:
http://www.iriver.com/flash/index.asp?code=0302
In the left column click Plus3 and go for the download.
Run iriver plus 3 and then select [Tools > Portable Device > Firmware Upgrade] from the menu.
Need more help ? Just post a comment.
In case you have the other model player, the H10, let me know if you need assistance for its recovery.
Dec 15, 2009 | iRiver H10 MP3 Player
IRiver H10 - System files missing
please, my new iriver h10 is not open. it will say "System files missing"
Aug 03, 2008 | iRiver H10 MP3 Player
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
I have no idea what to do! help!
To sync your device use either winamp or Iriver plus (winamp is better)
-Download winamp from http://www.winamp.com/player
-Iriver plus http://www.iriver.com/support/down_view.asp?idx=860
All firmware releases for your H10 can be found at: http://www.iriver.com/product/p_detail.asp?pidx=61
Jan 05, 2008 | iRiver H10 MP3 Player
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
IRiver H10 Wont Turn on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Oct 15, 2007 | iRiver H10 MP3 Player
IRiver MP3 Player Not Inisializing
If you haven't already I would try an emergency connect. -First perform a standard reset as you did before (press rear button for 20GB or disconnect & reconnect the battery for the 5/6GB versions). -Leave the unit turned off, but connect it to your computer's USB port. -Hold down the "o" button and then press the power button for a second to power on the device. -Do not release the "o" button until you see a message such as "emergency connect" or "mass storage" on the player screen. I beleive the message has changed with firmware versions, but it should be something similar. -If this works it should be detected by your computer as an external drive. You should have access to the files. -I would remove all music files from the device and then use the iriver plus software to restore system files. -If you manage to get to this point I would install the newest firmware available for your model of H10, found at the iriver site. The newest firmware adds a lot of functionality, speeds up player response significantly, and fixes many bugs as well.
Dec 03, 2006 | iRiver H10 MP3 Player
IRiver H10 missing all text
Try reinstalling the firmware
Aug 25, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
